Error while minimizing.
Hi all,
please find below my lammps input script and log file. Iam trying to minimize the slab with 1526 atoms and use modified tersoff potential. Iam getting this warning: Resetting reneighboring criteria during minimization. Also, the energy remains unchanged as seen below.So, no minimization occurs.
Could somebody please advise how do I get rid of the warning and minimize my slab.
atom_style atomic
#--------Reading Configuration----------
read_data configforrunwithoutOatoms.txt
#–Masses–##
mass 1 28.0855
mass 2 15.9994
pair_style tersoff
pair_coeff * * SiO.tersoff Si O
group moving id <> 1 667
group fixed id <> 668 1526
#----initial velocity-----
min_style quickmin
minimize 1.0e-6 1.0e-4 1000 10000
#timestep 0.0005
neighbor 0.7 bin
neigh_modify every 1 delay 10 check yes
#------output files-------------------------------
dump SilicaDump all custom 1000 dump.starting id type x y z vx vy vz
dump SilicaDump1 all xyz 100 dump.Startingxyz.xyz
thermo_style custom step temp press pe etotal
thermo 20
run 500
Log File:
WARNING: Resetting reneighboring criteria during minimization
Memory usage per processor = 0.448807 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0 -8528.3632 0 -8528.3632 -3589.8371
1 1.6707646e-07 -8528.3632 0 -8528.3632 -3589.8371
Loop time of 0.00640008 on 12 procs for 1 steps with 1526 atoms
Minimization stats:
Stopping criterion = energy tolerance
Energy initial, next-to-last, final =
-8528.36322586 -8528.36322586 -8528.36322586
Force two-norm initial, final = 109.484 109.484
Force max component initial, final = 12.005 12.005
Final line search alpha, max atom move = 0 0
Iterations, force evaluations = 1 1
Regards,
Saketh.
The minimizer tells you why it stopped. The energy didn't change
on the 1st step, so it thinks it is done. Is your system already
in a minimum energy config? Also when you say modified Tersoff,
does that mean you modified something?
