Thank you so much for both of your reply. After that I built LAMMPS with the kokkos package in the cluster I use. Unfortunaltely, I am still getting this error with a simpler model. I am explaining with the details below.
The LAMMPS version I am using is 23 Jun 2022 - Update 4.
**Output from ./lmp -h is attached and KOKKOS was built.
lmp-h OUTPUT.txt (12.7 KB)
My problem -
Now, I started with a simpler experiment. There are 14 polymeric chains aligned with each other and fixed at the ends. The part which are not fixed are in the “mobile” group used for computation. The thermal conductivity is attempted to be computed along Z direction (length of polymer). There is periodic boundary condition along Z direction and -s boundary condition along X and Y. I am using REAXFF potential and trying to compute the thermal conductivity by the RNEMD (fix thermal/conductivity) method.
An image of the equilibrated structure is attached below.
Whenerver, I am issuing a command like this below, there is no compute by the fix
fix NVT mobile nvt temp 300.0 300.0 10
compute ke mobile ke/atom
variable temperature atom c_ke/(1.58.617e-5)*
fix thermal mobile thermal/conductivity 300 z 100
thermo_style custom step temp pe ke etotal press lx ly lz f_thermal
run 7000000
Also attaching the log file below, which shows that the value of f_thermal is always coming to be 0. But the simulation is running and the structure looks stable as in the snapshot posted above. Can you please help me with this?
LOG FILE--------
Currently Loaded Modulefiles:
- hpcc/zaratan(default) 3) openmpi/gcc/9.4.0/zen2/4.1.1
- gcc/9.4.0(default)
/cvmfs/hpcsw.umd.edu/spack-software/2022.06.15/linux-rhel8-zen2/gcc-9.4.0/openmpi-4.1.1-hm2fkyfi7d5ggq4hg2xn4dtzf2o5r2rx/bin/mpirun
The library attempted to open the following supporting CUDA libraries,
but each of them failed. CUDA-aware support is disabled.
libcuda.so.1: cannot open shared object file: No such file or directory
libcuda.dylib: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.so.1: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.dylib: cannot open shared object file: No such file or directory
If you are not interested in CUDA-aware support, then run with
–mca opal_warn_on_missing_libcuda 0 to suppress this message. If you are interested
in CUDA-aware support, then try setting LD_LIBRARY_PATH to the location
of libcuda.so.1 to get passed this issue.
Kokkos::OpenMP::initialize WARNING: OMP_PROC_BIND environment variable not set
In general, for best performance with OpenMP 4.0 or better set OMP_PROC_BIND=spread and OMP_PLACES=threads
For best performance with OpenMP 3.1 set OMP_PROC_BIND=true
For unit testing set OMP_PROC_BIND=false
LAMMPS (23 Jun 2022 - Update 4)
KOKKOS mode is enabled (src/KOKKOS/kokkos.cpp:106)
will use up to 0 GPU(s) per node
WARNING: When using a single thread, the Kokkos Serial backend (i.e. Makefile.kokkos_mpi_only) gives better performance than the OpenMP backend (src/KOKKOS/kokkos.cpp:218)
Reading data file …
orthogonal box = (-50.2845 -50.0175 -7.025989) to (60.7155 80.9825 407.101)
2 by 2 by 4 MPI processor grid
reading atoms …
22358 atoms
Finding 1-2 1-3 1-4 neighbors …
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
special bonds CPU = 0.001 seconds
read_data CPU = 0.140 seconds
6384 atoms in group Carbon
10668 atoms in group Hydrogen
5306 atoms in group Oxygen
294 atoms in group leftend
154 atoms in group rightend
448 atoms in group Ends
21910 atoms in group mobile
Displacing atoms …
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Your simulation uses code contributions which should be cited:
- pair reaxff command:
- fix qeq/reaxff command:
The log file lists these citations in BibTeX format.
Neighbor list info …
update every 10 steps, delay 50 steps, check yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 19 22 70
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair reax/c/kk, perpetual
attributes: half, newton off, ghost, kokkos_device
pair build: half/bin/newtoff/ghost/kk/device
stencil: full/ghost/bin/3d
bin: kk/device
(2) fix qeq/reax/kk, perpetual, copy from (1)
attributes: half, newton off, kokkos_device
pair build: copy/kk/device
stencil: none
bin: none
Setting up Verlet run …
Unit style : real
Current step : 0
Time step : 0.5
Per MPI rank memory allocation (min/avg/max) = 17.33 | 18.75 | 20.52 Mbytes
Step CPU Temp Press Volume PotEng E_vdwl v_eb v_ea v_elp v_ev v_epen v_ecoa v_ehb v_et v_eco v_ew Lx Ly Lz Pxx Pyy Pzz
0 0 0 8828.8495 6021820.6 -2379978.3 -2321236.3 -3240461.9 -39378.314 53.658969 82141.52 0.36457227 -18.848419 -394.70039 68960.271 -13192.68 821054.33 111 131 414.12699 -194.18434 11784.645 14896.088
50 3.2412442 472.89605 4361.4346 6021820.6 -2412017.8 -2342064.9 -3343222.3 -95435.014 0.0091842318 91944.846 0.29749198 -83.758785 -480.65672 58796.868 -10319.435 956734.26 111 131 414.12699 7125.4433 1247.8409 4711.0195
Loop time of 3.24144 on 16 procs for 50 steps with 22358 atoms
Performance: 0.666 ns/day, 36.016 hours/ns, 15.425 timesteps/s
99.3% CPU use with 16 MPI tasks x 1 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 1.3966 | 1.9591 | 2.5623 | 23.2 | 60.44
Bond | 4.235e-06 | 9.0704e-06 | 1.9638e-05 | 0.0 | 0.00
Neigh | 0.00514 | 0.0065032 | 0.011911 | 1.9 | 0.20
Comm | 0.016386 | 0.6198 | 1.1823 | 41.3 | 19.12
Output | 0.00020707 | 0.00024406 | 0.00031789 | 0.0 | 0.01
Modify | 0.64905 | 0.65508 | 0.65717 | 0.2 | 20.21
Other | | 0.0006688 | | | 0.02
Nlocal: 1397.38 ave 1876 max 978 min
Histogram: 1 3 1 2 3 2 0 1 1 2
Nghost: 2427.38 ave 2968 max 1851 min
Histogram: 2 0 2 2 2 2 2 1 1 2
Neighs: 139229 ave 186670 max 97790 min
Histogram: 1 1 4 1 2 3 1 0 1 2
Total # of neighbors = 2227666
Ave neighs/atom = 99.636193
Ave special neighs/atom = 0
Neighbor list builds = 1
Dangerous builds = 1
WARNING: Using ‘neigh_modify every 1 delay 0 check yes’ setting during minimization (src/min.cpp:187)
Setting up cg/kk style minimization …
Unit style : real
Current step : 50
Per MPI rank memory allocation (min/avg/max) = 18.01 | 19.32 | 20.8 Mbytes
50 0 472.89605 4361.4335 6021820.6 -2412017.8 -2342064.9 -3343222.3 -95435.014 0.0091842318 91944.846 0.29749198 -83.758785 -480.65672 58796.868 -10319.435 956734.26 111 131 414.12699 7125.4406 1247.8407 4711.019
[compute-b7-50.zaratan.umd.edu:1063439] 15 more processes have sent help message help-mpi-common-cuda.txt / dlopen failed
[compute-b7-50.zaratan.umd.edu:1063439] Set MCA parameter “orte_base_help_aggregate” to 0 to see all help / error messages
500 160.48713 472.89605 452.45967 6021820.6 -2467164 -2402519.7 -3279952.5 -109202.33 -2.5752608e-06 83793.361 0.090378073 -59.671075 -518.22963 47526.249 -10590.91 866484.21 111 131 414.12699 202.24285 267.3579 887.77825
552 182.31407 472.89605 441.72687 6021820.6 -2467516 -2402671.3 -3279570.9 -109336.21 -2.5687561e-06 83820.633 0.089701245 -59.278863 -549.36288 47242.741 -10611.802 866392.87 111 131 414.12699 216.04129 264.35128 844.78803
Loop time of 182.314 on 16 procs for 502 steps with 22358 atoms
99.5% CPU use with 16 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = energy tolerance
Energy initial, next-to-last, final =
-2412017.83510368 -2467516.02200665 -2467516.02176074
Force two-norm initial, final = 16044.011 493.76582
Force max component initial, final = 267.80848 61.144764
Final line search alpha, max atom move = 0.00020443243 0.012499973
Iterations, force evaluations = 502 2618
Pair | 77.515 | 105.71 | 136.42 | 161.9 | 57.98
Bond | 0.00022993 | 0.00041284 | 0.00091056 | 0.0 | 0.00
Neigh | 0 | 0 | 0 | 0.0 | 0.00
Comm | 0.56355 | 31.086 | 59.222 | 297.2 | 17.05
Output | 0.059045 | 0.059053 | 0.059086 | 0.0 | 0.03
Modify | 45.08 | 45.127 | 45.187 | 0.6 | 24.75
Other | | 0.3341 | | | 0.18
Neighbor list builds = 0
Dangerous builds = 0
System init for write_restart …
Unit style : real
Current step : 552
Time step : 0.5
Per MPI rank memory allocation (min/avg/max) = 17.79 | 19.08 | 20.52 Mbytes
552 0 293.98846 351.22054 6021820.6 -2467516 -2402671.3 -3279570.9 -109336.21 -2.5687561e-06 83820.633 0.089701245 -59.278863 -549.36288 47242.741 -10611.802 866392.87 111 131 414.12699 166.64003 155.53647 731.48513
1000 28.857037 293.8783 56.628429 6021820.6 -2454066.1 -2385227.2 -3266904 -112373.27 -4.6739323e-06 91964.198 0.097382092 -64.505944 -2381.1752 50325.62 -10197.807 864403.63 111 131 414.12699 -46.409526 -0.64368165 216.9385
1500 61.32138 294.98119 -72.683825 6021820.6 -2454635.6 -2385611.1 -3267159.9 -112309.67 -4.6339226e-06 93644.801 0.097286942 -66.158802 -2011.2742 48591.268 -10211.998 863911.72 111 131 414.12699 -90.54505 -73.256375 -54.25005
2000 93.954531 292.94402 -88.002495 6021820.6 -2455196.7 -2386196.1 -3266682.3 -112231.54 -4.5739619e-06 94176.388 0.097166855 -66.723477 -1966.59 47487.079 -10212.713 863300.21 111 131 414.12699 -22.119555 5.8568246 -247.74475
2500 126.95164 296.89558 -85.643639 6021820.6 -2455898.1 -2386653.7 -3267451.3 -112090.61 -4.6511661e-06 94064.02 0.096809483 -67.833999 -2077.3809 47335.619 -10223.408 863857.03 111 131 414.12699 -62.134473 38.847607 -233.64405
3000 160.48192 294.2264 -122.90436 6021820.6 -2456326 -2387071.2 -3267820.5 -111827.64 -4.6996283e-06 94017.074 0.098726374 -66.045379 -2077.9106 46962.98 -10251.903 863992.66 111 131 414.12699 -71.054019 11.818622 -309.47767
3500 194.31028 294.06109 -134.60921 6021820.6 -2457285.6 -2387807.5 -3267566.5 -112139.36 -4.7291073e-06 93811.645 0.097725225 -66.126272 -2225.1286 46683.384 -10243.209 863937.67 111 131 414.12699 -41.768468 -59.315772 -302.74338
4000 228.95997 294.23599 -40.740347 6021820.6 -2457555.1 -2387941.9 -3268556.7 -111621.07 -4.683541e-06 93803.315 0.099577611 -66.485962 -2267.128 46548.804 -10274.594 864491.93 111 131 414.12699 57.563251 23.957401 -203.74169
4500 264.32793 290.98896 -89.687102 6021820.6 -2457903.8 -2388306.7 -3267702.9 -111804.48 -4.7286792e-06 93865.774 0.099065418 -67.098987 -2291.7807 46074.877 -10259.677 863878.56 111 131 414.12699 -23.219679 -35.706731 -210.1349
5000 300.36455 293.15896 -91.728048 6021820.6 -2458570.8 -2388725.4 -3268335.5 -111619.2 -4.7366289e-06 93589.966 0.099709156 -66.254085 -2389.4289 46173.069 -10264.263 864186.11 111 131 414.12699 -69.646136 16.236923 -221.77493
5500 337.04904 293.36685 -56.245028 6021820.6 -2458745.5 -2388870.5 -3268205.6 -111631.17 -4.7396857e-06 93880.9 0.099707829 -66.809767 -2433.8268 45828.53 -10262.765 864020.18 111 131 414.12699 22.895986 34.929253 -226.56032
6000 374.21946 295.01512 -106.80537 6021820.6 -2459187.3 -2389243 -3267614 -111867.43 -4.7885297e-06 93675.592 0.099070724 -66.632145 -2512.9341 45698.229 -10259.038 863703.08 111 131 414.12699 -26.76769 -49.345921 -244.3025
6500 411.71482 292.88214 -44.745911 6021820.6 -2459353.7 -2389306.4 -3267912.2 -111560.55 1.0417292e-05 93568.3 0.10013268 -68.644727 -2512.3374 45721.111 -10266.971 863724.74 111 131 414.12699 -4.0570271 37.585979 -167.76668
7000 449.92759 294.59569 -45.636714 6021820.6 -2459760.4 -2389604.5 -3268362.9 -111408.5 -4.6778013e-06 93445.476 0.10090968 -66.215937 -2590.3242 45849.419 -10279.24 863807.67 111 131 414.12699 7.2630146 26.300834 -170.47399
7500 488.57388 294.59494 -14.988278 6021820.6 -2459880.6 -2389714.1 -3268488.2 -111461.26 -4.6711421e-06 93638.918 0.099694711 -65.500546 -2610.2716 45434.846 -10274.594 864111.83 111 131 414.12699 47.266258 37.086672 -129.31776
8000 527.48245 296.09744 -78.703549 6021820.6 -2460157.8 -2389847.9 -3268733.7 -111487.71 1.8459419e-05 93523.824 0.09990421 -66.201218 -2592.0513 45389.254 -10265.797 864384.4 111 131 414.12699 -37.797656 -9.7843521 -188.52864
8500 566.40912 294.30908 -44.264269 6021820.6 -2460453.5 -2390103.1 -3268554.9 -111359.52 0.00019102209 93563.639 0.099957039 -66.816704 -2749.9666 45473.475 -10273.368 863864.27 111 131 414.12699 46.39223 2.5627208 -181.74776
9000 605.95432 292.9753 -56.683407 6021820.6 -2460463.9 -2390137.9 -3268012.4 -111700.74 -4.8275546e-06 93672.634 0.10058048 -65.870698 -2663.9136 45249.582 -10274.257 863656.94 111 131 414.12699 22.360664 4.4644719 -196.87536
9500 646.46054 294.93961 -71.384307 6021820.6 -2460599.2 -2390117.2 -3269117.5 -111368.69 0.0017364977 93691.788 0.10042214 -65.229158 -2719.3601 45383.829 -10281.04 864358.89 111 131 414.12699 -9.2876732 19.055384 -223.92063
10000 688.39074 295.04625 -61.199027 6021820.6 -2460916.9 -2390411.6 -3268012.4 -111405.49 -4.7928136e-06 93541.96 0.10060033 -66.656757 -2773.4285 45364.277 -10290.322 863230.33 111 131 414.12699 -42.45192 12.68096 -153.82612
93500 12183.105 292.65149 -165.17339 6021820.6 -2466332.6 -2393616.9 -3268244.8 -111488.99 7.52835e-06 94125.315 0.10057305 -65.487852 -4147.6679 44119.805 -10275.619 862360.49 111 131 414.12699 -91.737421 -86.149112 -317.63363
94000 12261.814 293.06901 -103.91467 6021820.6 -2466103 -2393431.3 -3267978.7 -111380.45 0.0010248413 93922.335 0.10168618 -67.485362 -4116.1487 44239.265 -10285.474 862235.31 111 131 414.12699 -13.364838 -15.496277 -282.8829
94500 12340.774 292.92508 -57.682861 6021820.6 -2466329.5 -2393671.2 -3267950.3 -111282.75 -4.9143445e-06 93728.361 0.10228358 -65.618595 -4145.4519 44343.665 -10297.257 861998.12 111 131 414.12699 -6.6345409 10.495906 -176.90995
95000 12419.162 291.66753 -64.621737 6021820.6 -2466006 -2393300.7 -3268254.9 -111341.63 -4.9823446e-06 93895.76 0.10248137 -67.860252 -4162.7847 44413.222 -10290.255 862507.68 111 131 414.12699 -1.5792883 18.784212 -211.07013
95500 12496.316 291.90056 -121.68537 6021820.6 -2466372.8 -2393689.6 -3267673.7 -111442.81 0.0041056328 93728.802 0.10115168 -65.9251 -4129.073 44299.936 -10285.003 861878.01 111 131 414.12699 -49.77014 -59.301938 -255.98402
96000 12573.808 295.56186 -60.255667 6021820.6 -2466236.8 -2393529.3 -3268705 -111121.7 0.0012254607 93723.252 0.10287899 -66.144502 -4104.7748 44416.271 -10299.735 862628.4 111 131 414.12699 -10.599739 -0.33430233 -169.83296
96500 12651.339 294.20856 -157.60895 6021820.6 -2466241.5 -2393645.6 -3267791.8 -111483.79 1.0352677e-05 93930.746 0.1008419 -66.030455 -4089.0023 44192.494 -10283.519 861945.28 111 131 414.12699 -72.686984 -74.436534 -325.70333
97000 12728.881 294.68983 42.168012 6021820.6 -2466122.9 -2393383.7 -3269206.1 -110765.27 0.00031317334 93813.006 0.10290118 -66.110846 -4114.5207 44442.735 -10307.528 862820.02 111 131 414.12699 159.82452 69.783446 -103.10393
97500 12806.22 292.83516 -126.09759 6021820.6 -2465997.8 -2393383.3 -3268133.2 -111324.55 0.00010345185 94060.914 0.10205916 -66.411865 -4093.8484 44280.965 -10285.449 862178.23 111 131 414.12699 -0.28177503 -76.22646 -301.78452
98000 12883.587 295.2778 -62.762301 6021820.6 -2466308.9 -2393578.7 -3267760.3 -111415.02 0.00023447357 94050.257 0.10143733 -66.660047 -4151.7936 44213.69 -10284.9 861835.91 111 131 414.12699 21.602924 15.568224 -225.45805
98500 12960.246 293.52578 -71.727615 6021820.6 -2466251.6 -2393520.3 -3268215.8 -111221.25 -4.8570346e-06 94024.456 0.10224376 -66.487624 -4144.2457 44288.031 -10296.689 862111.57 111 131 414.12699 42.30513 -50.164368 -207.32361
99000 13036.644 295.82687 -162.55076 6021820.6 -2465991.9 -2393299.2 -3267537 -111573.54 0.00063503709 94264.669 0.10216623 -66.23871 -4090.0091 44227.464 -10274.601 861749.95 111 131 414.12699 -45.461948 -125.17241 -317.01793
99500 13112.674 295.4157 -27.91636 6021820.6 -2466138.7 -2393465.7 -3268230.6 -111218.48 -4.9497562e-06 93974.093 0.102782 -66.392743 -4118.7615 44224.353 -10292.068 862261.96 111 131 414.12699 45.841217 40.70597 -170.29627
100000 13188.955 292.79008 -81.393212 6021820.6 -2466408.5 -2393686 -3268443 -111324.95 0.00078575882 93877.631 0.10181618 -67.187041 -4136.5965 44310.745 -10293.458 862390.68 111 131 414.12699 33.797286 -49.382506 -228.59442
100500 13265.007 295.88343 -68.084446 6021820.6 -2466104.3 -2393407.9 -3268129.6 -111345.51 -4.8412291e-06 94324.884 0.10037727 -66.728911 -4182.1389 44124.13 -10286.867 862153.78 111 131 414.12699 17.683375 -9.3206983 -212.61601
100552 13272.952 294.86783 -127.09374 6021820.6 -2466401.7 -2393712.8 -3267339.7 -111585.09 0.00046836992 93970.719 0.10175848 -68.157062 -4180.8981 44186.311 -10277.705 861581.59 111 131 414.12699 -38.945025 -31.247571 -311.08863
Loop time of 13273 on 16 procs for 100000 steps with 22358 atoms
Performance: 0.325 ns/day, 73.739 hours/ns, 7.534 timesteps/s
Pair | 4733.7 | 6951.5 | 9115 |1821.8 | 52.37
Bond | 0.0086036 | 0.019122 | 0.044236 | 6.1 | 0.00
Neigh | 17.027 | 21.807 | 27.518 | 81.7 | 0.16
Comm | 715.63 | 3138.8 | 5033.8 |2616.6 | 23.65
Output | 3.1283 | 3.1293 | 3.1371 | 0.1 | 0.02
Modify | 2928.2 | 3156.8 | 3695 | 557.7 | 23.78
Other | | 0.8993 | | | 0.01
Nlocal: 1397.38 ave 2274 max 237 min
Histogram: 1 2 0 1 2 3 1 0 3 3
Nghost: 3568.06 ave 5414 max 2489 min
Histogram: 3 1 4 2 1 3 0 0 1 1
Neighs: 377001 ave 617766 max 86187 min
Histogram: 2 1 1 1 0 5 0 2 3 1
Total # of neighbors = 6032015
Ave neighs/atom = 269.79224
Neighbor list builds = 2000
Dangerous builds = 2000
WARNING: New thermo_style command, previous thermo_modify settings will be lost (src/output.cpp:904)
Unit style : real
Current step : 100552
Time step : 0.5
Per MPI rank memory allocation (min/avg/max) = 26.52 | 31.95 | 39.42 Mbytes
Step Temp PotEng KinEng TotEng Press Lx Ly Lz f_thermal
100552 294.86783 -2466401.7 19650.573 -2446751.1 -127.09328 111 131 414.12699 0
105000 293.25831 -2466232.7 19543.312 -2446689.4 -104.53902 111 131 414.12699 0
120000 292.26325 -2466357.1 19476.999 -2446880.1 -139.52807 111 131 414.12699 0
135000 293.24414 -2466582.9 19542.367 -2447040.6 -62.821061 111 131 414.12699 0
The input files and data files are attached below. Thank you so much for the help.
in.thermal (2.9 KB)
data.hybrid (990.7 KB)
ffield.reax (16.7 KB)
Regards,
