Hi everyone,
I’m new with LAMMPS so please bear with me.
As part of my master thesis, I’m trying to model the addition of particles into a fluid and deform it with a shear force.
I have created 8 different particles with atom_style sphere inside a cubic boundary, then the output is saved in a file and read by another script which specifies the particle interactions and stress forces. I want to include a pair_style lubricate/poly in the calculation but I get the following error:
ERROR: Pair lubricate requires monodisperse particles (src/COLLOID/pair_lubricate.cpp:548)
According to the LAMMPS documentations on pair_style lubricate:
Style lubricate requires monodisperse spherical particles; style lubricate/poly allows for polydisperse spherical particles.
Since my particles are defined as spheres and I’m using lubricate/poly so I can use multiple particles I don’t understand why I’m getting that error. If I only leave one particle the program runs correctly, so it does not seem to be a problem with my particle definition.
I appreciate any help or advice you can give me.
Thank you!
EDIT: The LAMMPS version I’m using is from March 3 2020 running on Linux (Ubuntu 20.04)
Here is a simplified version of my two files (first I run file 1 and then file 2) with randomized values for confidentiality, (though this part is mostly based on the code from the published paper " Simulating dense non-Brownian suspension rheology using LAMMPS" by Christopher Ness, [2108.04606] Simulating dense granular suspension rheology using LAMMPS)
# file 1
# SETTINGS
units micro
atom_style sphere
comm_modify mode single vel yes
# GENERATE A CUBIC, PERIODIC SIMULATION BOX
region reg prism 0 1000 0 1000 0 1000 0 0 0 units box
create_box 4 reg
# GENERATE THE PARTICLES AND SPECIFY THEIR SIZE
create_atoms 1 random 10 123456 NULL
create_atoms 2 random 20 123457 NULL
create_atoms 3 random 30 123458 NULL
create_atoms 4 random 40 123459 NULL
set type 1 diameter 1
set type 2 diameter 2
set type 3 diameter 3
set type 4 diameter 4
set type 1 density 13
set type 2 density 13
set type 3 density 13
set type 4 density 13
# SPECIFY THE PARTICLE-PARTICLE INTERACTION
pair_style granular
pair_coeff * * hooke 10000 0 tangential linear_history 7000 0 0.1
# SPECIFY THE OUTPUTS
thermo 10000
dump id all custom 10000 create.dump id x y z radius
log create.log
# SPECIFY THE TIMESTEP, THE INTEGRATION SCHEME AND RUN
timestep 0.0001
fix 1 all nve/sphere
fix 2 all viscous 1.88 scale 2 2 scale 3 3 scale 4 4
run 1000000
# WRITE AN OUTPUT FILE
write_data data.file
# file 2
# SETTINGS
units micro
atom_style sphere
newton off
# READ THE PARTICLE CONFIGURATION
read_data data.file
pair_style hybrid/overlay granular lubricate/poly 0.1 1 1 0.001 0.05 1 0
pair_coeff * * granular hooke 10000 0 tangential linear_history 7000 0 0.1
pair_coeff * * lubricate/poly
# pair_coeff * * lubricate/poly
# DO THE STRESS CALC
compute Temp all temp/profile 1 1 1 xyz 10 10 10
compute str all pressure Temp
thermo_style custom time c_str[1] c_str[2] c_str[3] c_str[4] c_str[5] c_str[6]
thermo 10000
thermo_modify format line "%.0f %12.4e %12.4e %12.4e %12.4e %12.4e %12.4e"
dump id all custom 10000 run.dump id x y z radius
log run.log
timestep 0.0001
fix 2 all deform 1 xy erate 0.1 remap v
run 3000000
a) please always report your LAMMPS version and platform that you are running on.
b) please provide a minimal input example to reproduce the issue.
Please note that this error message is only possible when using pair style lubricate and not pair style lubricate/poly. So it looks as if LAMMPS is behaving exactly as documented.
Thank you for your response!
I have updated my original post to include the version and input information you suggested.
As for the pair style lubricate, in my script I’m using lubricate/poly so I don’t understand why LAMMPS is doing the calculation only with lubricate. Is there any other command I should be adding so lubricate/poly is used? Or maybe a specific package?
Thank you very much for your time
Kind regards
It looks more like your version of LAMMPS has a bug that was since fixed. I can run the second input without an error. Here is the beginning of the output
LAMMPS (24 Mar 2022)
Reading data file ...
triclinic box = (0 0 0) to (1000 1000 1000) with tilt (0 0 0)
reading atoms ...
100 atoms
reading velocities ...
100 velocities
read_data CPU = 0.001 seconds
generated 0 of 6 mixed pair_coeff terms from geometric mixing rule
Neighbor list info ...
update every 1 steps, delay 10 steps, check yes
master list distance cutoff = 4.1
ghost atom cutoff = 4.1
binsize = 2.05, bins = 488 488 488
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair granular, perpetual
attributes: half, newton off, size, history
pair build: half/size/bin/newtoff
stencil: full/bin/3d
bin: standard
(2) pair lubricate/poly, perpetual
attributes: full, newton off
pair build: full/bin/atomonly
bin: standard
Setting up Verlet run ...
Unit style : micro
Current step : 0
Time step : 0.0001
Per MPI rank memory allocation (min/avg/max) = 469 | 469 | 469 Mbytes
Time c_str[1] c_str[2] c_str[3] c_str[4] c_str[5] c_str[6]
0 0.0000e+00 0.0000e+00 0.0000e+00 -4.6338e-08 0.0000e+00 0.0000e+00
1 1.3972e-09 0.0000e+00 0.0000e+00 -4.6338e-08 0.0000e+00 0.0000e+00
Thank you for the response!
I have tried updating my version of LAMMPS to the one from 24 March 2022, both on windows and Linux, and I still get the same error. Could you please point me to your exact version (whether on windows or linux, if it is mac I’m afraid I won’t be able to reproduce it), and maybe the packages, in case it has some influence?
Thanks again.
Kind regards
As I already mentioned, it is not possible with a recent version of LAMMPS (platform doesn’t matter) to get this error message when using the lubricate/poly pair style.
You must be using a different input file (perhaps in a different folder) than what you posted here.
Well, I am uninstalled the version of LAMMPS I was using and intsalled the one from the 24th of Mars 2022 and I am using the exact same input files I said in my original message. Could the way I am launching LAMMPS be the root of the problem? I am using the following commands:
For the in.create (file1):
lmp -in in.create -pk omp 8 -sf omp
For the in.run2 (file2):
lmp -in in.run2 -pk omp 4 -sf omp
The in.create works well. The full console output of the in.run2 is the following.
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
using multi-threaded neighbor list subroutines
set 4 OpenMP thread(s) per MPI task
reading atoms ...
100 atoms
100 velocities
read_data CPU = 0.006 seconds
ERROR: Pair lubricate requires monodisperse particles (src/COLLOID/pair_lubricate.cpp:549)
Last command: run 3000000
As you can see, the LAMMPS version is the most recent one, yet that error appears.
I’d truly appreciate any advice or input.
Kind regards,
Yes, it is. The input will run without enabling the OPENMP package version.
You have found a very old bug in pair style lubricate/poly/omp that went undetected for almost 10 years.
You need to apply the following change:
diff --git a/src/OPENMP/pair_lubricate_poly_omp.h b/src/OPENMP/pair_lubricate_poly_omp.h
index 4b783784b4..d88a0f5630 100644
--- a/src/OPENMP/pair_lubricate_poly_omp.h
+++ b/src/OPENMP/pair_lubricate_poly_omp.h
@@ -17,7 +17,7 @@
#ifdef PAIR_CLASS
// clang-format off
-PairStyle(lubricate/poly/omp,PairLubricateOMP);
+PairStyle(lubricate/poly/omp,PairLubricatePolyOMP);
// clang-format on
#else
and recompile or not use the OpenMP version.
The benefit of using OpenMP parallelization for pair styles like these is limited anyway and requires benchmarking. There is a good chance that your simulations will run faster without.
Thank you very much for your help!
It seems to be working without the Omp so now I can move on with my research
Thank you once again!
Kind regards
