Please post to the list, not to me.
Assuming you have setup your problem the
same way for using both files …
a) you have the same mixture of Fe and Zr atoms
b) the atom types (1.2) correspond to the way
you defined the pair_coeff command and assigned
elements from the 2 different potential files
to the atom types
then I don’t see why a FeZr file should give different
results from a ZrFe file.
I’ve CCd Xiaowang who created the EAM database tool to see if
he agrees.
