Error
I am getting the error mentioned below. I checked one of the earlier posts where Steve has mentioned that,
(I am using Ubuntu 14.04 LTS )
<b>Either it isn't in a location that your Windows executable
is finding it, or there is some Windows issue with opening/
accessing the file, e.g. file permissions.
</b>
However i checked my input and every thing seems to be ok, pls help me to fix this problem
Reading restart file …
restart file 6 jun 2014, LAMMP = 6 Jun 2014
WARNING: Restart file used different # of processors (…/read_restart.cpp:678)
orthogonal box = (1.60537 2025517 -6.09556) to (18.4594 17.8096 26.1604)
1 by 1 by 2 MPI processor grid
686 atoms
ERROR on proc 0; Cannot open EAM potential file …/…/…/…/…/potentials/CuZr_mm.eam.fs (…/pair_eam_fs.cpp:130)
application called MPI_Abort (MPI_COMM_WORLD, 1) - process 0
Thanks in advance
Regards
Anik S
Your input is not OK because LAMMPS cannot find the EAM potential file you specify. Is it really located at …/…/…/…/…/potentials/CuZr_mm.eam.fs from where you run LAMMPS?
