Hi Everyone,
I have been trying to run the code from this 2010 paper modeling water contact angles on graphene. When I run the input and data file from the paper, I am continuously met with errors no matter the troubleshooting/ rearrangement.
The following data file results in “ERROR: Invalid atom type in Masses section of data file: Pair Coeffs (src/read_data.cpp: 2111)” as if the following section title “Pair Coeffs” were in the place of an atom type.
When I move the Masses section to the end so that nothing follows it, I get the error “Expected integer parameter instead of ‘Angle/Pair/Bond (depending on the arrangement of the sections)’ in input script or data file (src/read_data.cpp:2581)”
How can I prevent these errors? It seems like no matter what I do (I’ve tried changing the number of atoms, adding spaces/comments) the section titles are as integers.
11376 atoms
4000 bonds
2000 angles
0 dihedrals
0 impropers
3 atom types
1 bond types
1 angle types
0.000000000 117.888000 xlo xhi
0.000000000 119.109700 ylo yhi
0.000000000 300.000000 zlo zhi
Masses
1 15.9994 # O
2 1.00797 # H
3 12.011 # C
Pair Coeffs
1 0.1552976020 3.1655200879
2 0.0000000000 0.0000000000
3 0.0231060600 3.2144799121
Angle Coeffs
1 0.00 109.47
Atoms
#(Atom No. Molecule No. Atom Type. Partial Charge X Y Z)
1 1 3 0 0 0 0 …
5376 1 3 0 67.54 118.4008 0
5377 2 1 -0.8476 83.227380 72.295855 7.40030 …
11376 2001 2 0.4238 65.496380 52.676955 14.57930
Bonds
1 1 5377 5378 …
4000 1 11374 11376
Angles
1 1 5378 5377 5379 …
2000 1 11375 11374 11376
Bond Coeffs
1 0. 1.
Is this a formatting issue? Maybe it’s due to a difference in version (since the paper says the code was done in the 2009 version)? How can I fix this so I can run the files?
Here is my input file for reference:
units real
processors 1 1 1
neighbor 2.0 bin
atom_style full
#atom_style atomic
pair_style lj/cut/coul/long 14.0
pair_modify mix arithmetic
kspace_style pppm 1.0E-6
bond_style harmonic
angle_style harmonic
read_data lammps_GRA
group water type 1 2
fix 1 water shake 0.000001 500 0 b 1 a 1
velocity water create 300.0 2358 dist gaussian
group graphine type 3
fix 2 graphine setforce 0.0 0.0 0.0
fix 3 water nvt 300.0 300.0 100.
neigh_modify exclude group graphine graphine
timestep 1.0
thermo 1000
restart 200000 sio2.dump
dump 1 all atom 50000 dump.all
dump 2 water atom 1000 dump.water
run 400000
Thank you!
