I’m trying to increase the initial velocity of the atoms in my simulation, but I keep getting errors.
If I use the following code:
variable v_vx equal 2.0*vx
velocity all create 300.0 87287 loop geom
velocity all set v_vx NULL NULL
I receive an error saying “variable name for velocity set does not exist.”
If I use this code:
variable v_vx0 equal $v_vx
I receive the error “ERROR in proc 0: substitution for illegal variable.”
I have been to the velocity and variable command pages, as well as the section for errors, and I cannot find the reason for this error and how to fix it.
Any suggestions or advice would be greatly appreciated.
Thank you,
Casey
Casey Hansen
casey.e.hansen@…24…
The variable should be named “vx”
and referenced in the velocity command
as “v_vx”. The doc page for the velocity
command explains this.
You don’t need to add the “v_” before your variable.
I receive an error saying "variable name for velocity set does not exist.”
From your input, the velocity set command is expecting a variable named “v_v_vx”.
If I use this code:
This “$v_vx” is wrong - it should be “v_v_vx"
This should be “v_v_vx0"
I suggest you re-read the variable doc page more carefully.
Ray
