Ewald Parameters
Just a quick question. I want to use the same Ewald setting as show in the reference “using the particle-mesh Ewald method with a mesh width of 0.12 nm and an interpolation order of 4” But I do not know how to set these parameters after I read the manual carefully.
I really appreciate for any help!
Regards,
Hongru
LAMMPS does not have a Particle-Mesh Ewald (PME) implemented. You can either have a plain Ewald summation (slow for large systems) or a Particle-Particle Particle-Mesh (PPPM) summation. The latter is closer to PME, and you can set its parameters individually via the kspace_modify command.
please try reading the manual more carefully.
Hi Axel,
Thanks again!
One more question do you have any idea about the unite of PPPM mesh? Is it a distance unit?
Hongru
Hongru Ding, Graduate Student
Department of Mechanical Engineering
The University of Texas at Austin
Group: http://zheng.engr.utexas.edu
Hi Axel,
Thanks again!
it is unitless. those are the number of grid points in each direction.
Thank you so much, Axel!
Hongru
