I’m using ewald in my simulations by specifying:
kspace_style ewald 0.0001
After reading that pppm is Nlog(N) I substituted the following:
kspace_style pppm 0.0001
and the following message was generated. I did not received this message with the ewald run.
Does this occur due to the system I am simulating? or do I need a smaller precision value?
Thanks in advance,
-Bruce
ERROR on proc 7: Out of range atoms - cannot compute PPPM (pppm.cpp:1490)
[Profmembrane.local:07856] MPI_ABORT invoked on rank 7 in communicator MPI_COMM_WORLD with errorcode 1
mpiexec noticed that job rank 0 with PID 7849 on node Profmembrane.local exited on signal 15 (Terminated).
6 additional processes aborted (not shown)
<<<< LAMMPS SCRIPT >>>>
Epoxy Know Original Recipe with longer equilibration times at hot temperature
and MM minimization every round
units real
atom_style full
#package gpu force 0 0 -1
#newton off
#pair_style lj/class2/coul/long/gpu 9.5 10.0
pair_style lj/class2/coul/long 9.5 10.0
bond_style class2
angle_style class2
dihedral_style class2
improper_style class2
#kspace_style pppm 0.0001
kspace_modify order 6
read_data dgeba_ipd_cff91.lammps05
#read_data dgebaipd5x20.lammps05
timestep 1.0
neighbor 4.0 bin
neigh_modify every 1 delay 0 check yes page 1000000 one 100000
#compute peratom all stress/atom virial
#compute p all reduce sum c_peratom[1] c_peratom[2] c_peratom[3]
#variable press equal -(c_p[1]+c_p[2]+c_p[3])/(3*vol)
#compute mypress all pressure thermo_temp
#compute p all reduce sum c_mypress[1] c_mypress[2] c_mypress[3] c_mypress[4] c_mypress[5] c_mypress[6]
#variable press equal mypress
thermo_style custom step pe ke etotal lx ly lz temp press
thermo 2000
#Minimize the system using LAMMPS
dump 1 all atom 10 dgebasipd_min_fire_quad-3.lammpstrj
min_style cg
min_modify line quadratic
fix 1 all box/relax aniso 1.0 vmax 0.001
minimize 0 0 10000000 10000000
unfix 1
min_style fire
minimize 0.000000000001 0.000000000001 10000 10000
write_restart dgebaipd_min_fire_quad-4.%.*
#undump 1
#dump 1 all atom 20 sxyz_quench.lammpstrj
Was using Tg - 40 now using 298.0
#fix 1 all temp/rescale 1 298.0 298.0 2.0 1.0
#fix 2 all nve
fix 1 all nvt temp 298.0 298.0 100.0
timestep 0.001
run 10000
timestep 0.01
run 10000
timestep 0.1
run 10000
timestep 1.0
run 10000
unfix 1
#unfix 2
Checkpoint the calculations for restart
write_restart sxyz_quench.%.*
