Dear users,
I am learning the examples in KAPPA to calculate thermal conductivity by direct thermostatting method. I am facing several problems by learning these examples.
First, I am confused by the fix langevin command in the input file "in.langevin" as shown in the following. There are several commands in the last part:
"region hot block INF INF INF INF 0 1
region cold block INF INF INF INF 10 11
compute Thot all temp/region hot
compute Tcold all temp/region cold
fix 1 all nve
fix hot all langevin \{thi\} {thi} 1.0 59804 tally yes
fix cold all langevin \{tlo\} {tlo} 1.0 287859 tally yes
fix_modify hot temp Thot
fix_modify cold temp Tcold
The explanation of fix langevin is " fix ID group-ID langevin Tstart Tstop damp seed keyword values". The question is why "all" group-ID are fixed in "fix hot all langevin \{thi\} {thi} 1.0 59804 tally yes"
and "fix cold all langevin \{tlo\} {tlo} 1.0 287859 tally yes"? Is this correct? Should I define groups for atoms in the hot and cold region, respectively, and then specify corresponding group-id in
fix langevin ?
Second, I am trying to simulate thermal conductivity of my system and came up with the following lines for performing the thermostatting:
fix 1 all nve
fix 7 all langevin 315.0 315.0 1.0 292252 tally yes
fix_modify 7 temp Thot
fix 8 all langevin 285.0 285.0 1.0 287859 tally yes
fix_modify 8 temp Tcold
variable tdiff equal c_Thot-c_Tcold
thermo_style custom step temp c_Thot c_Tcold f_hot f_cold v_tdiff
thermo 1000
However, the f_hot and f_cold variables stops printing data with "Step 7 8 " in the log file . But the code continues running. If I delete f_cold and f_hot from thermo_style command, it prints the other data to log file very well.
I would be highly grateful if you can take your time and tell what I am doing wrong.
John
in. langevin :
# sample LAMMPS input script for thermal conductivity of liquid LJ
# thermostatting 2 regions via fix langevin
# settings
variable x equal 10
variable y equal 10
variable z equal 20
variable rho equal 0.6
variable t equal 1.35
variable rc equal 2.5
variable tlo equal 1.0
variable thi equal 1.70
#variable rho equal 0.85
#variable t equal 0.7
#variable rc equal 3.0
#variable tlo equal 0.3
#variable thi equal 1.0
# setup problem
units lj
atom_style atomic
lattice fcc ${rho}
region box block 0 $x 0 $y 0 $z
create_box 1 box
create_atoms 1 box
mass 1 1.0
velocity all create $t 87287
pair_style lj/cut ${rc}
pair_coeff 1 1 1.0 1.0
neighbor 0.3 bin
neigh_modify delay 0 every 1
# heat layers
# 1st equilibration run
fix 1 all nvt temp $t $t 0.5
thermo 100
run 1000
velocity all scale $t
unfix 1
# 2nd equilibration run
fix 1 all nve
thermo 1000
run 10000
# thermal conductivity calculation
# reset langevin thermostats to zero energy accumulation
compute ke all ke/atom
variable temp atom c_ke/1.5
fix ave all ave/time 10 100 1000 v_tdiff ave running
thermo_style custom step temp c_Thot c_Tcold f_hot f_cold v_tdiff f_ave
fix 2 all ave/spatial 10 100 1000 z lower 0.05 v_temp &
file profile.langevin units reduced
run 20000
