I am very new to LAMMPS and have been trying to figure out how to use the create_atoms. I am just trying to define a 3d region and then fill it with particles, ideally at a specified packing fraction or with a specific number of particles. I have just been using the example given in the documentation but the output of the coordinates doesn’t match the picture provided in the documentation (sinusoidal wave).
units lj
dimension 2
region box block 0 50 0 50 -0.5 0.5
create_box 1 box
create_atoms 1 random 2000 13487 NULL overlap 1.0 maxtry 50
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
write_dump all atom coords2.txt
The output looks like the following
ITEM: TIMESTEP
0
ITEM: NUMBER OF ATOMS
2000
ITEM: BOX BOUNDS pp pp pp
-5.0000000000000000e+01 5.0000000000000000e+01
-5.0000000000000000e-01 5.0000000000000000e-01
ITEM: ATOMS id type xs ys zs
1 1 0.497041 0.764961 0.5
2 1 0.153896 0.536377 0.5
3 1 0.396365 0.708224 0.5
4 1 0.322652 0.81345 0.5
5 1 0.520825 0.510146 0.5
6 1 0.314503 0.857443 0.5
7 1 0.0393217 0.880628 0.5
8 1 0.168315 0.863787 0.5
9 1 0.406776 0.682612 0.5
The entire output file shows the coordinates as being within 0 and 1, but to my mind at least the x-coordinates should extend across the entire domain (0-50). Is this an issue with the write_dump statement or is this correct and there is implicitly some kind of transform that needs to be performed on the output?
