I used the get_dos_by_material_id of the MPRester class but I´m not so sure what the result is representing. I know its a DOS object and I applyied the get_element_dos function. In the result is then a dict which contains list of values for orbitals. My question is what do these lists represent?
Hi @philip, could you clarify what you mean by list? When you call get_element_dos
, get_spd_dos
or get_element_spd_dos
, you should be given a dictionary where the keys are Element
or Orbital
objects, and the values are new Dos
objects that contain only the projected data for the referenced element or orbital.
– Jason
