exporting and sharing environment variables across multiple fireworks
What is the correct way to export and share environment variables within a workflow?
My trial involved the following procedure:
  1. I export an environment variable FOO in a script export_env.sh in a FireTask that is part of FireWork 1 as follows:
export FOO=BAR
  1. I source that script in the corresponding yaml file
  2. In a consecutive FireWork I execute a script call_env.sh in a FireTask in which that same environment variable is called:
echo "value of FOO: "$FOO
The yaml file would look like this:
fws:
  • fw_id: 1
    spec:
    _tasks:
    • _fw_name: ScriptTask
      script: . ./export_env.sh
      use_shell: true
  • fw_id: 2
    spec:
    _tasks:
      script: ./call_env.sh
      use_shell: true
As far as I experienced, environment variables set in 1 FireWork, are not retained in a consecutive FireWork, even when the native shell is used.
How do I go about setting environment variables that are accessible in multiple FireWorks and that can only be set dynamically, i.e. they cannot be exported beforehand?
Thanks!
This is a linux question as opposed to Fireworks. is there a reason you can’t write your export to a file, and then call “source” on that file in your “call_env.sh” ?
(Or, just put your variable in the file and read it directly?)
more generally: linux - Where should I export an environment variable so that all combinations of bash/dash, interactive/non-interactive, login/non-login, will pick it up? - Super User
Since you probably don’t want to modify these global files to get these dynamic exports to appear, I suggest you drop a file out or use the dynamic workflow functionality of fireworks to avoid this environment variable problem altogether:
https://pythonhosted.org/FireWorks/dynamic_wf_tutorial.html
export FOO=BAR
  1. In a consecutive FireWork I execute a script call_env.sh in a FireTask in which that same environment variable is called:
fws:
  • fw_id: 1
spec:
_tasks:
- _fw_name: ScriptTask
  use_shell: true
  • fw_id: 2
spec:
_tasks:
  use_shell: true
Thanks!
Hi all
Chris is correct that you should refresh your knowledge on sourcing vs executing bash scripts to set environment variables. Also, I would suggest going through the basic FWS tutorials. The one on how to pass data is:
Anubhav
more generally: http://superuser.com/questions/636219/where-should-i-export-an-environment-variable-so-that-all-combinations-of-bash-d
https://github.com/materialsproject/fireworks/tree/master/fw_tutorials/dynamic_wf
export FOO=BAR
fws:
  • fw_id: 1
spec:
_tasks:
  use_shell: true
  • fw_id: 2
spec:
_tasks:
  use_shell: true
Thanks!
