jacob,
unless you are changing the energy as part of something that is called in the “middle” of a timestep, it will have no effect whatsoever.
so using fix_external to execute a callback function is the way to go.
from this point onward, however, there is currently no way to continue with C, you need to dig fairly deep into the inner workings of LAMMPS and use some C++ code. i am currently working on a significant refactoring and improved documentation for the library interface(s). I think it should be possible to update the library interface to not only set the callback function but also call the functions to set the per atom or global energy or stress values for the fix, if combined with first defining a suitable compute, you can use the call back to “set” the energy by subtracting the existing energy contributions from the value you want to set.
back to the “hackish” C++ variant. the fewest lines of C++ code, would be to directly overwrite the energy in the corresponding accumulator variables.
assuming you have only a pair style, those are LAMMPS_NS::Pair::eng_vdwl and LAMMPS_NS::Pair::eng_coul. if you have other styles contributing to the (potential) energy, those need to be overwritten as well.
please see below of a short test code. if you put the mycallback() function into a separate file, then this is the only file that needs to be compiled with a C++ compiler. it has to use C bindings to be compatible with the callback signature.
#include “library.h”
#include “lammps.h”
#include “force.h”
#include “pair.h”
#include “fix_external.h”
#include <mpi.h>
#include <stdio.h>
#include <string.h>
extern “C” void mycallback(void *ptr, long int timestep,
int nlocal, int *ids,
double **x, double **fexternal);
LAMMPS_NS::LAMMPS *lmp = (LAMMPS_NS::LAMMPS )ptr;
double my_pe = (500.0 - timestep)/100.0; / new energy: (500-step)/100 */
lmp->force->pair->eng_vdwl = my_pe;
lmp->force->pair->eng_coul = 0.0;
int main(int argc, char **argv)
void *handle;
int i;
MPI_Init(&argc, &argv);
lammps_open(0, NULL, MPI_COMM_WORLD, &handle);
lammps_file(handle,“in.ar.real”);
lammps_command(handle,“thermo_style custom step pe”);
lammps_command(handle,“thermo 1”);
lammps_command(handle,“fix ext all external pf/callback 1 1”);
lammps_set_fix_external_callback(handle,(char *)“ext”,&mycallback,handle);
lammps_command(handle,“run 0 post no”);
lammps_command(handle,“run 1 pre no post no”);
lammps_close(handle);
MPI_Finalize();
return 0;
this produces the following output:
LAMMPS (5 May 2020)
Lattice spacing in x,y,z = 5.79518 5.79518 5.79518
Created orthogonal box = (0 0 0) to (28.9759 28.9759 28.9759)
Created 500 atoms
create_atoms CPU = 0.00173871 secs
Neighbor list info …
update every 20 steps, delay 0 steps, check no
master list distance cutoff = 9.8112
ghost atom cutoff = 9.8112
binsize = 4.9056, bins = 6 6 6
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair lj/cut, perpetual
attributes: half, newton on
pair build: half/bin/atomonly/newton
stencil: half/bin/3d/newton
bin: standard
Setting up Verlet run …
Unit style : real
Current step : 0
Time step : 11.1903
Per MPI rank memory allocation (min/avg/max) = 2.644 | 2.644 | 2.644 Mbytes
Step Temp PotEng Press v_temp v_epair v_emol v_etotal v_press
0 117.7 -1.6612661 -1909.5509 1 -7.1026383 0 -5.6056383 -5.1203128
10 87.369977 -1.5728967 -1169.6414 0.74231077 -6.7248204 0 -5.6135812 -3.1363029
20 42.567295 -1.4427006 -150.87379 0.36165926 -6.1681752 0 -5.6267713 -0.40455638
30 55.130978 -1.480902 -387.17817 0.46840253 -6.3315028 0 -5.6303042 -1.0381883
40 55.054202 -1.4807485 -401.72653 0.46775023 -6.3308469 0 -5.6306248 -1.0771986
50 56.873955 -1.4860029 -428.9126 0.48321117 -6.3533113 0 -5.6299442 -1.1500959
60 58.33701 -1.490161 -458.23636 0.49564154 -6.3710892 0 -5.6291138 -1.2287253
70 61.29671 -1.4991528 -539.72484 0.52078768 -6.4095331 0 -5.629914 -1.4472304
80 63.214984 -1.504992 -594.34987 0.53708567 -6.4344983 0 -5.630481 -1.5937032
90 61.936907 -1.5013008 -569.13985 0.5262269 -6.4187169 0 -5.6309552 -1.5261045
100 62.20662 -1.5023046 -585.49121 0.52851844 -6.4230083 0 -5.6318162 -1.5699494
Loop time of 0.0972865 on 1 procs for 100 steps with 500 atoms
Performance: 993.809 ns/day, 0.024 hours/ns, 1027.892 timesteps/s
99.0% CPU use with 1 MPI tasks x 1 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
