Hi lammps-users,
I am having some trouble with the fix deposit command. I’m using ReaxFF and trying to add some iron atoms into the void space of a box that is otherwise occupied by a diamond crystal. I’m not currently focused on getting them into a particular location or arrangement, I just need to get them in the box. I keep getting the warning “WARNING: Particle deposition was unsuccessful (fix_deposit.cpp:347)” and I can’t figure out the cause. I’ve looked through the mailing list and documentation without result and the error isn’t too instructive. I don’t think the error is associated with reaxFF but I could be wrong. The script is below.
Matt Thompson
Initializations
units real
atom_style charge
lattice diamond 3.5668
region mybox block 0 5 0 5 0 5
create_box 1 mybox
create_atoms 1 region mybox
mass 1 12.011
velocity all create 10 12345
Interaction definitions
pair_style reax/c NULL checkqeq yes
pair_coeff * * ffield-FeCHO.reax 1
neighbor 4.0 bin
neigh_modify check yes
Integrator Definitions
fix 1 all nvt temp 298 298 100
fix 4 all qeq/reax 1 0.0 10 1.0e-6 reax/c
timestep 0.001
dump initial trajectory and write to restart file
dump 1 all xyz 1 diamond.xyz
run 1
write_restart restart.diamond
Expand box by a factor of 3 in y to give space for new atoms
change_box all y scale 3
Add iron atoms to box
fix 5 all deposit 100 4 10 12345 region mybox global 5 10 near 2.0 units box
thermo 10
dump 2 all atom 10 added_iron.lammpstrj
dump_modify 2 scale no
run 1000
fix-deposit-errors.tar (30 KB)
Since you’re inserting into a region you’ve already filled with atoms via
create_atoms, how much “empty” space is there that has no
atom closer than 2.0 Angs (in your fix deposit command)?
Are you inserting 0 atoms, or just some of them are unsuccessful?
Have you visualized your system to insure after the change_box that
it is what you expect?
Hi Steve,
Thanks for the reply.
I’m inserting 0 atoms; all insertions fail.
Since you’re inserting into a region you’ve already filled with atoms via create_atoms, how much "empty"space is there that has no atom closer than 2.0 Angs (in your fix deposit command)?
In the log file, the original box (Created orthogonal box = (0 0 0) to (17.834 17.834 17.834)) was filled with carbon atoms and then expanded in y by a factor of 3 (orthogonal box = (0 -17.834 0) to (17.834 35.668 17.834)) to create 2x that original box size in void space. So only 1/3 of the box has atoms in it and there is plenty of space > 2.0 Angstroms away from another atom.
Yes, after applying periodic images in each dimension in VMD, it shows what I was expecting - alternating layers of atoms in the xz plane with empty space in a 1:2 ratio. I’ve attached that lammpstrj dump in case it would be useful. I dumped in between expanding the box with change_box and trying to add iron atoms with fix deposit.
Matt Thompson
expanded_box.lammpstrj (45.2 KB)
If you are using mybox as the region for fix deposit,
which you also used to create the atoms, then
isn’t it the region in the 1/3 of the final expanded box where
the atoms are? I.e. you need to define another
region in the void space to do the deposit into?
Steve,
Yes, that was the problem. I have defined a new region that includes only the void space and atom insertion works fine now. Thanks for your help.
Matt Thompson
