Dear all, especially dear Axel and Steve,
I have posted here previously about adding external one body potential V(x,y,z) for a system.
There was two suggestion and in the end I took Axel’s suggestion to implement it through
fix addforce and atom-style variables.
When I tried to test it I found that:
a) either I do not understand how to print out the potential energy of the system
b) or fix addforce does not add the energy to the potential energy for some reason
c) I have messed up something in the syntax of adding the potential to the system through “energy”
Please help me find out which is the case! Please note that when I print out the potential
it gives reasonable values, but potential energy with the “pe” variable always gives 0.
I do not ask you to check the details of the potential it is only provided for illustration.
Please find the relevant input bellow.
Thank you for your help in anticipation!
Janos
#input:
include “system.in.init”
PARAMETERS
variable pi equal 3.14159
variable b equal 4.83045
variable Ea equal 0.00698237
variable Ec equal 3.6749e-05
variable bb equal 0.423342
variable y0 equal 37.9585
#calculating the potential: PROBABLY NOT IMPORTANT ONLY FUNCTIONS OF x, y and z
variable Axz atom ({Ea}-{Ec}(6.0-4.0cos(2.0*${pi}x/b)*cos(2.0*{pi}z/b/sqrt(3.0))-2.0*cos(4.0*{pi}z/b/sqrt(3.0)))/9.0)
variable By atom (exp(-2.0*{bb}(y-{y0})-2.0*exp(-{bb}(y-${y0}))))
variable Vxyz atom (v_Axzv_By)
#calculating derivatives: PROBABLY NOT IMPORTANT ONLY FUNCTIONS OF x, y and z
variable CuFx atom (-1.0*{Ec}*8.0/9.0*{pi}/b*cos(2.0*{pi}z/b/sqrt(3.0))*sin(2.0*{pi}x/b)*v_By)
variable CuFy atom (-1.0*v_Axz*(-2.0*{bb}exp(-2.0{bb}*(y-{y0}))+2{bb}*exp(-1*{bb}(y-{y0}))))
variable CuFz atom (-1.0*{Ec}8.0/9.0${pi}/sqrt(3.0)/b*sin(4.0*{pi}*z/sqrt(3.0)/$b)*v_By)
#Apply the force on the Xe atom: PLEASE CHECK THIS PART
fix field Xe addforce v_CuFx v_CuFy v_CuFz energy v_Vxyz
#Printing out quantities: PLEASE CHECK THIS PART
compute ener all reduce sum v_Vxyz
variable e equal c_ener
variable p equal pe
thermo 1
thermo_style custom pe c_ener #this gives 0 and some meaningful number for c_ener
fix extra all print 1 “{p} {e}” file ener.dat #this one does the same
#one note:
#the system is set up with no other potential then the one body V(x,y,z)
#eg in system.in.init
units electron
atom_style full
neigh_modify exclude type 1 1
kspace_style none
atom_modify sort 1 1.0
pair_style none
