Hello!
I am trying to upload cp2k data. But I get failed data processing related to parsers/cp2k… and I can not figure out the issue. It corresponds to a typical MD run by cp2k, with .inp, .out, .xyz and a restart file.
upload id: KZGEg2lOQFu9sup5pzxX9w
I am getting:
“errors”: string"parser failed with exception"
“event”: string"process failed"
“proc”: string"Entry"
“process”: string"process_entry"
“process_worker_id”: string"eJv7h7SpSyWYm4ZoI9RqDw"
“parser”: string"parsers/cp2k"
“error”: string"‘NoneType’ object has no attribute ‘atomic_numbers’"
“step”: string"parsers/cp2k"
“logger”: string"nomad.processing"
“exception”: string"Traceback (most recent call last): File “/usr/local/lib/python3.9/site-packages/nomad/processing/data.py”, line 1484, in parsing parser.parse( File “/usr/local/lib/python3.9/site-packages/nomad/parsing/parser.py”, line 460, in parse self.mainfile_parser.parse(mainfile, archive, logger) File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1806, in parse self.parse_method_quickstep() File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1597, in parse_method_quickstep basis_set=self._parse_basis_set(), File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1569, in _parse_basis_set ac.atom_number = self.get_atomic_number(atom.kind_label) File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 847, in get_atomic_number atomic_numbers = self.out_parser.get( AttributeError: ‘NoneType’ object has no attribute ‘atomic_numbers’"
Dear Guido, thank you for reaching out.
This sounds similar to a recent bug fix that has not yet been put into production.
Let me see if the bug fix works, else I open an issue to track this.
I guess you haven’t published your upload yet. That’s completely fine, but I won’t have access to look into it.
To do this securely, pls add [email protected] as a reviewer to your upload. (I’m linking this page as proof of accreditation: https://www.fairmat-nfdi.eu/fairmat/about-fairmat/team-fairmat)
As such, I will be able to see it. Pls also provide me with the specific entry id of the process that’s failing.
I will download these files to test them locally for debugging purposed. They are removed afterwards.
That’s correct. Just, the dataset connected would be the .xyz file (now it sais no dataset…), the author name sounds wrong (no S. Cooper connected to this data), and that it would be useful in the future to be able to set “structure type” as amorphous at one point. All good for the rest.
S. Cooper is just a test account. Nothing will be published under this name.
All of this was done with a local installation that already has the patch. The public one just needs it rolled out.
Metadata like the dataset will reflect whichever dataset you attached.
I stumbled upon this issue with a test-upload. We are in the process of selecting a long-term feasible solution for publishing DFT-based datasets, with the possibility to utilize the API in other simulation-solutions based on the DFT calculated parameters.
My test-upload is a number of files from one of our calculations with CP2Kv2023.2. I also tried a local install but it seems it is based on a much older CP2K version, not able to parse necessary details from the main output.
“root”:{
“errors”:string"parser failed with exception"
“event”:string"process failed"
“proc”:string"Entry"
“process”:string"process_entry"
“process_worker_id”:string"qt49RQoKThi2iHC6YxcwVg"
“parser”:string"parsers/cp2k"
“error”:string"‘NoneType’ object has no attribute ‘atomic_numbers’"
“step”:string"parsers/cp2k"
“logger”:string"nomad.processing"
“exception”:string"Traceback (most recent call last): File “/usr/local/lib/python3.9/site-packages/nomad/processing/data.py”, line 1484, in parsing parser.parse( File “/usr/local/lib/python3.9/site-packages/nomad/parsing/parser.py”, line 460, in parse self.mainfile_parser.parse(mainfile, archive, logger) File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1806, in parse self.parse_method_quickstep() File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1597, in parse_method_quickstep basis_set=self._parse_basis_set(), File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1569, in _parse_basis_set ac.atom_number = self.get_atomic_number(atom.kind_label) File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 847, in get_atomic_number atomic_numbers = self.out_parser.get( AttributeError: ‘NoneType’ object has no attribute ‘atomic_numbers’"
“timestamp”:string"2024-05-14 13:40.32"
“level”:string"ERROR"
The upload-ID is “xCS-EO4IQjiNYEIofmEGbA”. Not published, but I added you as reviewer.
Would that be possible to check it with your patch?
Or do you have any information on when the new version might be deployed to the main site?
Thank you very much in advance!
Best Regards,
Zoltán
i seem to have stumbled upon a similar problem. I tried to upload my simulation data for a WIP paper and the CP2K files failed to parse. I compiled CP2K from the main-branch on github and use some features that didn’t make it into an official release yet.
My upload ID is: vOI1IJqwSUSzrLrc2Wrvgw
I also added you as a Co-Author if you find the time to take a look.
I took note and am looking into the error. It isn’t the previous CP2K error, which I think has been released already.
I will let you know once I’ve found the bug.
thank you, Nathan,
I didn’t find the option to reprocess (just getting acquainted with the interface),
but tried another upload, with the same result (failure) unfortunately.
Added you as a reviewer to this upload_id, too: SD6gZ2JEQYq2JxydDfmElQ
File “/usr/local/lib/python3.9/site-packages/nomad/processing/data.py”, line 1499, in parsing
parser.parse(
File “/usr/local/lib/python3.9/site-packages/nomad/parsing/parser.py”, line 463, in parse
File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 2288, in parse
self.parse_settings()
File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1492, in parse_settings
section.m_set(section.m_get_quantity_definition(f’x_cp2k_{key}‘), val)
File “/usr/local/lib/python3.9/site-packages/nomad/metainfo/metainfo.py”, line 1769, in m_get_quantity_definition
return resolve_variadic_name(self.m_def.all_quantities, quantity_name, hint)
File “/usr/local/lib/python3.9/site-packages/nomad/metainfo/util.py”, line 602, in resolve_variadic_name
raise ValueError(f’Cannot find a proper definition for name {name}’)
ValueError: Cannot find a proper definition for name x_cp2k_id
Okay, thank you for checking. Good to know that it now produces a different error message. Were these the same files you uploaded?
Btw, you can reprocess an upload by navigating to it, then clicking in the upper-right corner the circle with 2 arrows, 5th symbol from the left. It says “Reprocess”, when you hover over it with your mouse.
Thanks for the quick response, Nathan,
Regarding the uploads: no, the second test set is a collection of files from a different calculation.
And thank you for the hint on the “reprocess” button. I was looking for it in – now obviously – the wrong place among the file panel options. Repeating the processing for the previous upload, I now get a different error, regarding DoS parsing, see below:
parser.parse(
File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 2302, in parse
self.parse_configurations_quickstep()
File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1993, in parse_configurations_quickstep
self.parse_dos(sec_run.calculation[-1], pdos_files)
File “/usr/local/lib/python3.9/site-packages/electronicparsers/cp2k/parser.py”, line 1765, in parse_dos
atom_kind_in_files_sorted = sorted(
TypeError: ‘<’ not supported between instances of ‘NoneType’ and ‘str’
I am encountering a new similar issue. I uploaded an MD trajectory obtained from CP2K as an entry, but after processing, it is indexed as a single DFT point instead of an MD workflow. I added you as a reviewer, as mentioned in a previous discussion regarding CP2K data.
Is there a specific procedure or setting during the upload process to ensure that the trajectory is correctly recognized as an MD workflow rather than a single DFT point?
Thanks in advance for any guidance!
Guido
Thank you for reaching out and right away sharing an example so I can reproduce the problem.
Simply put, the CP2K parser was never equipped to also handle MD calculations. I’ll see to add support for it. You can follow the progress of the issue here: Add support for MD to CP2K · Issue #274 · nomad-coe/electronic-parsers · GitHub
Moreover, would you be fine with me integrating the example you shared into our test stack?
Thank you for the quick feedback. Of course, you can use it as an example. I also plan to publish it soon together with other similar calculations, as long as it doesn’t interfere with the support work. Thanks again, as always.
