Dear LAMMPS users:
Hi, I was following the steps to run the alkane_chain_single with the codes from Moltemplate Examples, the guidance is to run the minimization first(run.in.min) and then run.in.nvt but when I ran the minimization the terminal showed this
ERROR on proc 0: Non-numeric atom coords - simulation unstable (…/domain.cpp:522)
Last command: minimize 1.0e-4 1.0e-6 100000 400000
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
system msg for write_line failure : Bad file descriptor
The code for the minimization is:
