Dear everyone,
I am trying to complile LAMMPS with the GPU package and cmake.
I have the following versions:
$ gmake --version
GNU Make 4.3
$ cmake --version
cmake version 3.22.1
The command I am using is the following:
cmake -D PKG_GPU=on …/cmake && cmake --build .
which produces the following error:
[ 1%] Performing build step for 'opencl_loader'
CMake Error at .../lammps-29Sep2021/build_GPU/opencl_loader-prefix/src/opencl_loader-stamp/opencl_loader-build-RelWithDebInfo.cmake:49 (me ssage):
Command failed: 2
'/usr/bin/gmake'
See also
.../lammps-29Sep2021/build_GPU/opencl_loader-prefix/src/opencl_loader-stamp/opencl_loader-build-*.log
which contains this error:
fatal error: EGL/egl.h: No such file or directory
#include <EGL/egl.h>
I have found this solution on the web, which works (maybe) only for windows:
can anyone help me here?
PS the normal “cmake --build .” works fine, while KOKKOS produces the same error.
Thank you
I am having trouble making sense of the error. Nothing in the OpenCL loader code includes this include file directly. It usually comes bundled with OpenGL support development support.
I am compiling on a linux cluster, specificly from an nvidia-gpu node and using cuda 11. More information below.
Regarding the cmake command, I have the following:
cmake ../cmake
cmake --build . #everything works
while when using the GPU option:
$ cmake -D PKG_GPU=on ../cmake
-- Appending /cm/local/apps/cuda/libs/current/lib64:/cm/shared/apps/cuda11.1/toolkit/11.1.1/targets/x86_64-linux/lib:/cm/shared/apps/slurm/18.08.9/lib64/slurm:/cm/shared/apps/slurm/18.08.9/lib64 to CMAKE_LIBRARY_PATH: /cm/local/apps/cuda/libs/current/lib64:/cm/shared/apps/cuda11.1/toolkit/11.1.1/targets/x86_64-linux/lib:/cm/shared/apps/slurm/18.08.9/lib64/slurm:/cm/shared/apps/slurm/18.08.9/lib64
-- Running check for auto-generated files from make-based build system
-- Checking for module 'mpi-cxx'
-- No package 'mpi-cxx' found
-- Downloading and building OpenCL loader library
-- Generating style headers...
-- Generating package headers...
-- Generating lmpinstalledpkgs.h...
-- Could NOT find ClangFormat (missing: ClangFormat_EXECUTABLE) (Required is at least version "8.0")
-- The following tools and libraries have been found and configured:
* Git
* OpenMP
-- <<< Build configuration >>>
Operating System: Linux CentOS Linux 7
Build type: RelWithDebInfo
Install path: /home/mdi0316/.local
Generator: Unix Makefiles using /usr/bin/gmake
-- Enabled packages: GPU
-- <<< Compilers and Flags: >>>
-- C++ Compiler: /cm/local/apps/gcc/8.2.0/bin/c++
Type: GNU
Version: 8.2.0
C++ Flags: -O2 -g -DNDEBUG
Defines: LAMMPS_SMALLBIG;LAMMPS_MEMALIGN=64;LAMMPS_OMP_COMPAT=3;LAMMPS_GZIP;LAMMPS_FFMPEG;LMP_GPU
-- <<< Linker flags: >>>
-- Executable name: lmp
-- Static library flags:
-- <<< GPU package settings >>>
-- GPU API: OPENCL
-- GPU precision: MIXED
-- Configuring done
-- Generating done
-- Build files have been written to: /home/mdi0316/CODES/lammps-29Sep2021/build_GPU
then building fails:
$ cmake --build .
[ 1%] Built target variable.h
Consolidate compiler generated dependencies of target mpi_stubs
[ 1%] Built target mpi_stubs
CMake Error at /home/mdi0316/CODES/lammps-29Sep2021/build_GPU/opencl_loader-prefix/src/opencl_loader-stamp/opencl_loader-build-RelWithDebInfo.cmake:49 (message):
Command failed: 2
'/usr/bin/gmake'
See also
/home/mdi0316/CODES/lammps-29Sep2021/build_GPU/opencl_loader-prefix/src/opencl_loader-stamp/opencl_loader-build-*.log
gmake[2]: *** [opencl_loader-prefix/src/opencl_loader-stamp/opencl_loader-build] Error 1
gmake[1]: *** [CMakeFiles/opencl_loader.dir/all] Error 2
gmake: *** [all] Error 2
Here’s more information on the gpu card.
$ nvidia-smi
Fri Jan 14 09:06:46 2022
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 Tesla K20Xm On | 00000000:04:00.0 Off | 0 |
| N/A 31C P8 29W / 235W | 0MiB / 5700MiB | 0% Default |
| | | N/A |
| 1 Tesla K20Xm On | 00000000:05:00.0 Off | 0 |
| N/A 31C P8 31W / 235W | 0MiB / 5700MiB | 0% Default |
| | | N/A |
| 2 Tesla K20Xm On | 00000000:08:00.0 Off | 0 |
| N/A 31C P8 30W / 235W | 0MiB / 5700MiB | 0% Default |
| | | N/A |
| 3 Tesla K20Xm On | 00000000:09:00.0 Off | 0 |
| N/A 33C P8 30W / 235W | 0MiB / 5700MiB | 0% Default |
| | | N/A |
| 4 Tesla K20Xm On | 00000000:84:00.0 Off | 0 |
| N/A 30C P8 30W / 235W | 0MiB / 5700MiB | 0% Default |
| | | N/A |
| 5 Tesla K20Xm On | 00000000:85:00.0 Off | 0 |
| | | N/A |
| 6 Tesla K20Xm On | 00000000:88:00.0 Off | 0 |
| N/A 32C P8 30W / 235W | 0MiB / 5700MiB | 0% Default |
| | | N/A |
| 7 Tesla K20Xm On | 00000000:89:00.0 Off | 0 |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
could the problem be the CMAKE_LIBRARY_PATH?
I have installed it locally and there is no global one.
cmake -D PKG_GPU=on -D GPU_API=cuda ../cmake
-- Configuring done
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_CUDA_LIBRARY (ADVANCED)
linked by target "nvc_get_devices" in directory /home/mdi0316/CODES/lammps-29Sep2021/cmake
linked by target "gpu" in directory /home/mdi0316/CODES/lammps-29Sep2021/cmake
-- Generating done
CMake Generate step failed. Build files cannot be regenerated correctly.
Therefore I am trying to explicitely linking CUDA_CUDA_LIBRARY as follows:
cmake -D PKG_GPU=on -D GPU_API=cuda -D CUDA_CUDA_LIBRARY=/cm/shared/apps/cuda11.1/toolkit/11.1.1/lib64 ../cmake
-- GPU API: CUDA
-- CUDA Compiler: /cm/shared/apps/cuda11.1/toolkit/11.1.1/bin/nvcc
-- GPU default architecture: sm_50
-- GPU binning with CUDPP: OFF
-- CUDA MPS support: OFF
-- Configuring done
WARNING: Target "gpu" requests linking to directory "/cm/shared/apps/cuda11.1/toolkit/11.1.1/lib64". Targets may link only to libraries. CMake is dropping the item.
WARNING: Target "lammps" requests linking to directory "/cm/shared/apps/cuda11.1/toolkit/11.1.1/lib64". Targets may link only to libraries. CMake is dropping the item.
WARNING: Target "lmp" requests linking to directory "/cm/shared/apps/cuda11.1/toolkit/11.1.1/lib64". Targets may link only to libraries. CMake is dropping the item.
WARNING: Target "nvc_get_devices" requests linking to directory "/cm/shared/apps/cuda11.1/toolkit/11.1.1/lib64". Targets may link only to libraries. CMake is dropping the item.
-- Generating done
-- Build files have been written to: /home/mdi0316/CODES/lammps-29Sep2021/build_GPU_CUDA
can you tell me how can I properly link these libraries?
Moreover, I cannot find explicitely the Tesla architecture in the documentation. Would that be a problem?
That is only the second best option. You should rather fix your CUDA toolkit installation to properly set the necessary environment variables (CUDA_HOME, PATH, LD_LIBRARY_PATH etc.)
You are obviously not using -DCUDA_CUDA_LIBRARY correctly. The error message tells you what the issue is. Just use a bit of common sense here.
When compiling with CMake LAMMPS will attempt to build so-called “fat” executables with PTX code included for all architectures supported by the CUDA toolkit in use, so the choice of the correct architecture is less crucial. Please note that your hardware is about to be phased out by the non-legacy nvidia drivers and not going to be supported by future CUDA toolkits.
Nevertheless, I’d like to understand what was wrong with my environment variables.
Could something be interfering? (cuda current = cuda 11.1.1, so that should not be the problem)
It is extremely difficult to diagnose your issues from remote. I suggest you Google for “cmake findcuda.cmake” and see what cmake uses to locate the cuda toolkit settings. It works properly on all machines that I am compiling on and also your original egl.h error for OpenCL hints that there is something inconsistent in the setup of the machine you are compiling on. I did another check with a CentOS 7 container and did not see any reference to that when compiling the opencl loader library.
