Dear Lammps Users
Is there a way in which I can ouput a dump file or a fix print to a file having a filename of the following format
filename.${firsttimestep}.txt
By firsttimestep I mean the timestep at which the simulation began (for instance it will be 1 if it is the first simulation or say 100000 if my first run ended in that timestep). The reason I require this is that, it avoids prinitng a large number of files if I use a * and also avoids overwriting the previous files, if I simply use “filename.txt”. This will make sure that I have x number of files where x corresponds to the number of times I have ran the scripts. I am not sure whether there is any other elegant way of doing this.
Thanks in advance
Regards
Vaidyanathan M S
