Has anyone experienced the error - FileExistsError: [Errno 17] File exists: '/app/run/gui' when trying to bring up the docker-based nomad-oasis app?
I tried the following solutions without success:
- run a removal command (
rm -rf /app/run/gui) inside docker (sudo docker exec -ti nomad_oasis_app /bin/bash) after executingsudo docker compose up. - Modified the command in yaml to clear that directory before running run.sh `
command: ["/bin/sh", "-c", "rm -rf /app/run/gui && ./run.sh"]
Anyone knows why this problem is happening and how I can solve this?
Portion of the logs added below:
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/nomad_plugin_gui/apis/__init__.py", line 75, in load
nomad_oasis_app | shutil.copytree(static_folder, run_gui_folder)
nomad_oasis_app | File "/usr/local/lib/python3.12/shutil.py", line 600, in copytree
nomad_oasis_app | return _copytree(entries=entries, src=src, dst=dst, symlinks=symlinks,
nomad_oasis_app | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
nomad_oasis_app | File "/usr/local/lib/python3.12/shutil.py", line 498, in _copytree
nomad_oasis_app | os.makedirs(dst, exist_ok=dirs_exist_ok)
nomad_oasis_app | File "<frozen os>", line 225, in makedirs
nomad_oasis_app | FileExistsError: [Errno 17] File exists: '/app/run/gui'
nomad_oasis_app | [2025-02-10 10:54:14 +0000] [27] [INFO] Worker exiting (pid: 27)
nomad_oasis_app | [2025-02-10 10:54:14 +0000] [26] [INFO] Worker exiting (pid: 26)
nomad_oasis_app | [2025-02-10 10:54:14 +0000] [29] [ERROR] Exception in worker process
nomad_oasis_app | Traceback (most recent call last):
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/arbiter.py", line 609, in spawn_worker
nomad_oasis_app | worker.init_process()
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/uvicorn/workers.py", line 75, in init_process
nomad_oasis_app | super().init_process()
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/workers/base.py", line 134, in init_process
nomad_oasis_app | self.load_wsgi()
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/workers/base.py", line 146, in load_wsgi
nomad_oasis_app | self.wsgi = self.app.wsgi()
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/app/base.py", line 67, in wsgi
nomad_oasis_app | self.callable = self.load()
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/app/wsgiapp.py", line 58, in load
nomad_oasis_app | return self.load_wsgiapp()
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/app/wsgiapp.py", line 48, in load_wsgiapp
nomad_oasis_app | return util.import_app(self.app_uri)
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/gunicorn/util.py", line 371, in import_app
nomad_oasis_app | mod = importlib.import_module(module)
nomad_oasis_app | File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
nomad_oasis_app | return _bootstrap._gcd_import(name[level:], package, level)
nomad_oasis_app | File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
nomad_oasis_app | File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
nomad_oasis_app | File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
nomad_oasis_app | File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
nomad_oasis_app | File "<frozen importlib._bootstrap_external>", line 995, in exec_module
nomad_oasis_app | File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
nomad_oasis_app | File "/opt/venv/lib/python3.12/site-packages/nomad/app/main.py", line 103, in <module>
nomad_oasis_app | api_app = entry_point.load()
nomad_oasis_app | [2025-02-10 10:54:14 +0000] [29] [INFO] Worker exiting (pid: 29)
nomad_oasis_app | [2025-02-10 10:54:14 +0000] [28] [INFO] Started server process [28]
nomad_oasis_app | [2025-02-10 10:54:14 +0000] [28] [INFO] Waiting for application startup.
nomad_oasis_app | [2025-02-10 10:54:17 +0000] [9] [ERROR] Worker (pid:26) exited with code 3
nomad_oasis_app | [2025-02-10 10:54:17 +0000] [9] [ERROR] Worker (pid:27) was sent SIGTERM!
nomad_oasis_app | [2025-02-10 10:54:17 +0000] [9] [ERROR] Worker (pid:29) was sent SIGTERM!
nomad_oasis_app | [2025-02-10 10:54:47 +0000] [9] [ERROR] Shutting down: Master
nomad_oasis_app | [2025-02-10 10:54:47 +0000] [9] [ERROR] Reason: Worker failed to boot.
