I was wondering if anyone has tried to fine-tune the recent CHGNet graph neural network potential. I’m having some basic use questions for how to fine-tune using some AIMD data. The README file has the following:
from chgnet.data.dataset import StructureData, get_train_val_test_loader
from chgnet.trainer import Trainer
dataset = StructureData(
structures=list_of_structures,
energies=list_of_energies,
forces=list_of_forces,
stresses=list_of_stresses,
magmoms=list_of_magmoms
train_loader, val_loader, test_loader = get_train_val_test_loader(
dataset,
batch_size=32,
train_ratio=0.9,
val_ratio=0.05
trainer = Trainer(
model=chgnet,
targets='efsm',
optimizer='Adam',
criterion='MSE',
learning_rate=1e-2,
epochs=50,
use_device='cuda'
trainer.train(train_loader, val_loader, test_loader)
The first question I have is what are the formats/data-types of the structures, energies, etc. in the lists passed to StructureData? Are they JSON? The second question is how do you save the weights and load them for later use? The third question is with regard to the note:
- The pretrained dataset of
CHGNetcomes from GGA+U DFT withMaterialsProject2020Compatibility. The parameter for VASP is described inMPRelaxSet. If you’re fine-tuninig withMPRelaxSet, it is recommended that apply theMP2020compatibility to your energy labels so that they’re consistent with the pretrained dataset.
I’m not sure what the implications are on GGA AIMD simulations data using Nose-Hoover thermostat.
If anyone has put together a Jupyter notebook that demonstrates fine-tuning using some AIMD data that would be extremely useful.
