Very helpful thanks. I uninstalled the Python2.7 version. Installed pip3 and reinstalled Fireworks using pip3.
This gives me another error though:
[email protected]:~$ lpad reset
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 574, in _build_master
ws.require(__requires__)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 892, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 783, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (Jinja2 2.10 (/usr/lib/python3/dist-packages), Requirement.parse('Jinja2>=2.10.1'), {'flask'})
During handling of the above exception, another exception occurred:
File "/usr/local/bin/lpad", line 6, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3088, in <module>
@_call_aside
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3072, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3101, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 576, in _build_master
return cls._build_from_requirements(__requires__)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 589, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
This advice is general to installing any Python code, not just FireWorks. In general, installing a Python package should not require superuser privileges, so the sudo in sudo pip install fireworks is unnecessary.
Since different Python packages sometimes require different dependencies, and these might conflict with each other, it’s usually better to install into a clean virtualenv (or, equivalently, “conda env” if you’re using the conda package management system).
Depending on the specific Python version you’re using, there are a few ways to do this, but this should work:
Then lpad should be available. Regarding your specific error, I haven’t seen it before, but I suspect there’s some issue with dependency conflicts that came as a result for how python has been installed on your system.
