I am trying to reset the db as follows:
$ lpad reset
File "/home/mdi0316/anaconda3/bin/lpad", line 8, in <module>
sys.exit(lpad())
File "/home/mdi0316/anaconda3/lib/python3.8/site-packages/fireworks/scripts/lpad_run.py", line 1551, in lpad
args.func(args)
File "/home/mdi0316/anaconda3/lib/python3.8/site-packages/fireworks/scripts/lpad_run.py", line 197, in reset
lp = get_lp(args)
File "/home/mdi0316/anaconda3/lib/python3.8/site-packages/fireworks/scripts/lpad_run.py", line 142, in get_lp
raise ValueError(err_message) from None
ValueError: FireWorks was not able to connect to MongoDB at 10.100.192.1:27017. Is the server running? The database file specified was /home/mdi0316/.fireworks/my_launchpad.yaml.
Here’s the version of mongo/lpad/Fireworks that I am using:
$ which mongo
~/anaconda3/bin/mongo
$ mongo --version
MongoDB shell version v4.0.3
git version: 7ea530946fa7880364d88c8d8b6026bbc9ffa48c
OpenSSL version: OpenSSL 1.1.1n 15 Mar 2022
allocator: tcmalloc
modules: none
build environment:
distarch: x86_64
target_arch: x86_64
$ pip freeze | grep Fire
FireWorks==2.0.3
$ which lpad
~/anaconda3/bin/lpad
$ lpad --version
lpad v2.0.3 located in /home/mdi0316/anaconda3/lib/python3.8/site-packages
A mongod instance is running already:
$ mongod --bind_ip_all --logpath ~/mongodb/log/mongod.log --port 27017 --dbpath ~/mongodb/db --auth --fork
2022-05-13T16:04:52.605+0200 I CONTROL [main] Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'
about to fork child process, waiting until server is ready for connections.
forked process: 289628
child process started successfully, parent exiting
$ lsof -iTCP -sTCP:LISTEN | grep mongo
mongod 274693 mdi0316 10u IPv4 2391118783 0t0 TCP *:27017 (LISTEN)
and I have the following user defined:
> show dbs
admin 0.000GB
config 0.000GB
local 0.000GB
> use admin
switched to db admin
> show users
"_id" : "admin.mdi0316_admin",
"user" : "mdi0316_admin",
"db" : "admin",
"roles" : [
"role" : "userAdminAnyDatabase",
"db" : "admin"
"mechanisms" : [
"SCRAM-SHA-1",
"SCRAM-SHA-256"
and my config file looks like this:
$ cat ~/.fireworks/my_launchpad.yaml
authsource: mdi0316_admin
host: 10.100.192.1
logdir: null
mongoclient_kwargs: {}
password: *******
port: 27017
strm_lvl: INFO
uri_mode: false
user_indices: []
username: mdi0316_admin
wf_user_indices: []
I actually also tried the same with mongo 5.1.1 with no difference.
Thank you for your help.
Marco
