Fireworks With "Waiting" Status Not Launched
Over the weekend I submitted just over 500 jobs to Fireworks
(this is the largest pipeline I've tried to date) and executed
them using:
qlaunch -r rapidfire --nlaunches infinite --sleep 60 --maxjobs_queue 50
All but 6 of them completed successfully and I'm trying to figure
out what's happened with those 6. If I try "qlaunch" or
"rlaunch", neither command recognizes that there are few jobs
left to complete. For example:
$ qlaunch -r singleshot
2015-09-14 10:47:45,974 INFO No jobs exist in the LaunchPad for submission to queue!
Here are some (hopefully) relevant details. I'm happy to provide
more.
lpad get\_fws \-d count 514 lpad get_fws -s COMPLETED -d count
508
lpad get\_fws \-s WAITING \-d count 6 lpad get_fws -s FIZZLED -d count
0
Which Fireworks are waiting?
$ lpad get_fws -s WAITING | grep fw_id | sort
"fw_id": 32,
"fw_id": 33,
"fw_id": 34,
"fw_id": 35,
"fw_id": 36,
"fw_id": 37,
What was Firework with fw_id 31, and what happend to it?
$ lpad get_fws -i 31 -d more
[See https://gist.github.com/anonymous/10ea08044f574d190625]
Looking in the launch directory for fw_id 31 (and looking at the
yaml file I used to submit my workflow), I know that the Firework
with fw_id 31 should be (as far as I can tell) the only
dependency for the Firework with fw_id 32.
Was a launch directory ever created for the Firework with fw_id
32? It appears not:
grep \-rl '"fw\_id": 32,' \./\*
(the same is true for the other "waiting" Fireworks)
If I try to rerun these Firworks, still no luck:
lpad rerun\_fws \-i 32 lpad rerun_fws -i 32
2015-09-14 10:50:56,652 INFO Finished setting 1 FWs to rerun
2015-09-14 10:52:37,092 INFO No jobs exist in the LaunchPad for submission to queue!
Is there anything else I should try/check/examine?
Thank you,
Derek
PS: Apologies that this post also got appended to my previous "qluanching dependent jobs" thread
Hi Derek,
The “WAITING” state indicates that there is a job dependency, i.e. a parent job that the current job is waiting to be COMPLETED. Those FWs will not be picked up by rlaunch or qlaunch. Only “READY” jobs are set to be run. See a description of states here:
https://pythonhosted.org/FireWorks/reference.html#interpretation-of-state-of-fws-and-wfs
Next, you probably want to try to debug why the FW is not READY yet. One thing you can try is querying the state of all the jobs within the workflow of the affected FW, e.g.:
lpad get_wflows -i 31
where “31” is the id of one of your affected FWS. This should print out a report of all states in your workflow and you can probably see immediately where things got stuck.
If things are still not clear after that and you are confident that something might be wrong, type the command:
lpad get_wflows -i 31 -d all
and paste the result back into this list so I can take a look at all the links in the workflow and what is happening.
Anubhav
(this is the largest pipeline I’ve tried to date) and executed
them using:
–maxjobs_queue 50
All but 6 of them completed successfully and I’m trying to figure
out what’s happened with those 6. If I try “qlaunch” or
“rlaunch”, neither command recognizes that there are few jobs
Here are some (hopefully) relevant details. I’m happy to provide
more.
$ lpad get_fws -d count
514
$ lpad get_fws -s COMPLETED -d count
508
$ lpad get_fws -s WAITING -d count
6
$ lpad get_fws -s FIZZLED -d count
0
“fw_id”: 32,
“fw_id”: 33,
“fw_id”: 34,
“fw_id”: 35,
“fw_id”: 36,
“fw_id”: 37,
32? It appears not:
$ grep -rl ‘“fw_id”: 32,’ ./*
(the same is true for the other “waiting” Fireworks)
lpad rerun_fws -i 32 lpad rerun_fws -i 32
Thank you,
Derek
“qluanching dependent jobs” thread
Hi Anubhav,
Using lpad get_wflows, I see that one of the other dependencies for fw_id 32, fw_id 30, is still RUNNING according to:
$ lpad get_wflows -i 32 -d all | grep '"30"'
"30": "RUNNING",
However, lpad get_fws shows it as COMPLETED:
$ lpad get_fws -i 30
     "name": "Unnamed FW",
     "fw_id": 30,
     "state": "COMPLETED",
     "created_on": "2015-09-10T16:45:38.431775",
     "updated_on": "2015-09-10T16:52:00.453871"
The associated launcher_* for fw_id 30 directory has an empty .error file and a .out file indicating that the Rocket finished and completed. The output that the job produced also looks correct (I ran the command manually and the results match).
It seems odd that get_wflows and get_fws show different states for same job.
Happy to provide more info as necessary. The "-d all" option for lpad get_wflows produces a lot of output (it's a big workflow), but I can include it if it's helpful.
Regards,
Derek
On Mon, 14 Sep 2015, Anubhav Jain wrote:
Hi Derek,
The "WAITING" state indicates that there is a job dependency, i.e. a parent job that the current job is waiting to be COMPLETED. Those FWs will not be picked up by rlaunch or qlaunch. Only "READY" jobs are set to be run.
where "31" is the id of one of your affected FWS. This should print out a report of all states in your workflow and you can probably see immediately where things got stuck.
Anubhav
      them using:
      --maxjobs_queue 50
      more.
      508
      0
      "fw_id": 32,
      "fw_id": 33,
      "fw_id": 34,
      "fw_id": 35,
      "fw_id": 36,
      "fw_id": 37,
      [See https://gist.github.com/anonymous/10ea08044f574d190625\]
      32? It appears not:
      Thank you,
      Derek
Hi Derek,
Thanks for reporting this - there is a potential for the FW and WFlow states to not match; this is because a contributor had pushed a change to cache the FW states inside the WFlow to speed up the overall operation of FWS. This causes the storage of FW and WFlow states to be separate. Unfortunately, if there is a bug in this code, it would cause the problems that you see.
Do you happen to have any code example I can use to reproduce this problem? Then I can include it as a unit test and ask the contributor to fix it. We already have a basic unit test for this functionality and it passes, so I need an example of how to force a failure.
Also, if the “-all” option is too long, you can also use “lpad get_wflows -i 31 -d more” which will provide more information but not nearly as much as “all”.
Anubhav
On Tue, Sep 15, 2015 at 10:26 AM, Derek [email protected] wrote:
Hi Anubhav,
$ lpad get_wflows -i 32 -d all | grep ‘“30”’
“30”: “RUNNING”,
"fw_id": 30,
Happy to provide more info as necessary. The “-d all” option for lpad get_wflows produces a lot of output (it’s a big workflow), but I can include it if it’s helpful.
Regards,
Derek
Hi Derek,
Anubhav
  them using:
  --maxjobs_queue 50
  more.
  514
  508
  6
  0
  "fw_id": 32,
  "fw_id": 33,
  "fw_id": 34,
  "fw_id": 35,
  "fw_id": 36,
  "fw_id": 37,
  [See [https://gist.github.com/anonymous/10ea08044f574d190625](https://gist.github.com/anonymous/10ea08044f574d190625)]
  32?  It appears not:
  $ grep -rl '"fw_id": 32,' ./*
  $ lpad rerun_fws -i 32$ lpad rerun_fws -i 32
  Thank you,
  Derek
Hi Anubhav,
Here is a gist for the output of "lpad get_wflows -i 32 -d all":
The workflow that I submitted uses a bunch of external (to python) dependencies, so maybe not the easiest to replicate on another system.
I could try to make a dummy workflow where the firetasks are sleep commands--that would be portable. What exactly do you have in mind? I'm guessing this could be a timing-related issue, but beyond that I'm not sure.
Regards,
Derek
On Tue, 15 Sep 2015, Anubhav Jain wrote:
Hi Derek,
Also, if the "-all" option is too long, you can also use "lpad get_wflows -i 31 -d more" which will provide more information but not nearly as much as "all".
Anubhav
On Tue, Sep 15, 2015 at 10:26 AM, Derek <[email protected]> wrote:
      Hi Anubhav,
      "30": "RUNNING",
       "fw_id": 30,
      Regards,
      Derek
            Hi Derek,
            Anubhav
             them using:
             --maxjobs_queue 50
             more.
             lpad get\_fws \-d count &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 514 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; lpad get_fws -s COMPLETED -d count
             508
             lpad get\_fws \-s WAITING \-d count &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 6 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; lpad get_fws -s FIZZLED -d count
             0
             "fw_id": 32,
             "fw_id": 33,
             "fw_id": 34,
             "fw_id": 35,
             "fw_id": 36,
             "fw_id": 37,
             32? It appears not:
             grep \-rl &#39;&quot;fw\_id&quot;: 32,&#39; \./\* &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
             Thank you,
             Derek
Hi Derek,
Indeed, having a dummy workflow (with test tasks or with sleep tasks) that we can reproduce in its entirety would be ideal.
Anubhav
On Tue, Sep 15, 2015 at 3:13 PM, Derek [email protected] wrote:
Hi Anubhav,
Here is a gist for the output of “lpad get_wflows -i 32 -d all”:
https://gist.github.com/anonymous/df811ff4f1aec422e44d
I could try to make a dummy workflow where the firetasks are sleep commands–that would be portable. What exactly do you have in mind? I’m guessing this could be a timing-related issue, but beyond that I’m not sure.
Regards,
Derek
Hi Derek,
Anubhav
  Hi Anubhav,
  "30": "RUNNING",
      "fw_id": 30,
  Regards,
  Derek
        Hi Derek,
        [https://pythonhosted.org/FireWorks/reference.html#interpretation-of-state-of-fws-and-wfs](https://pythonhosted.org/FireWorks/reference.html#interpretation-of-state-of-fws-and-wfs)
        Anubhav
              them using:
              --maxjobs_queue 50
              more.
              514
              508
              6
              0
              "fw_id": 32,
              "fw_id": 33,
              "fw_id": 34,
              "fw_id": 35,
              "fw_id": 36,
              "fw_id": 37,
              32?  It appears not:
              Thank you,
              Derek
I experienced this bug using fireworks version 1.04. Has any of the caching code changed since then?
I'm happy to go through the git logs myself if I know which files to look in.
I'm going to first rerun my entire workflow (using version 1.04) and see how reproducible the behavior is. If it is perfectly reproducible, I'll try it again in 1.1.3. If it reproduces there, I'll make a bunch of test/dummy jobs and share that code with you.
Regards,
Derek
Hi Derek,
Anubhav
On Tue, Sep 15, 2015 at 3:13 PM, Derek > <[email protected]> wrote:
      Hi Anubhav,
      get_wflows_all.txt · GitHub
      another system.
      Regards,
      Derek
            Hi Derek,
            "all".
            Anubhav
            On Tue, Sep 15, 2015 at 10:26 AM, Derek > <[email protected]> wrote:
             Hi Anubhav,
             "30": "RUNNING",
             "fw_id": 30,
             "created_on":
            (I ran the
            it if it's helpful.
             Regards,
             Derek
             Hi Derek,
            "READY"
            f-fws-and-wfs
            type the command:
             Anubhav
             them using:
            infinite --sleep 60
             --maxjobs_queue 50
             more.
            count
             508
             0
            fw_id | sort
             "fw_id": 32,
             "fw_id": 33,
             "fw_id": 34,
             "fw_id": 35,
             "fw_id": 36,
             "fw_id": 37,
             [See
            fw_id 32.
             32? It appears not:
            still no luck:
            rerun_fws -i 32
            try/check/examine?
             Thank you,
             Derek
Hi Derek,
Examining the changelog (https://pythonhosted.org/FireWorks/changelog.html), I don’t see anything past 1.04 that would have affected this issue one way or the other. So if you are seeing it in 1.04 chances are that you will still see it in 1.1.3.
Anubhav
I’m happy to go through the git logs myself if I know which files to look in.
I’m going to first rerun my entire workflow (using version 1.04) and see how reproducible the behavior is. If it is perfectly reproducible, I’ll try it again in 1.1.3. If it reproduces there, I’ll make a bunch of test/dummy jobs and share that code with you.
Regards,
Derek
Hi Derek,
Anubhav
  Hi Anubhav,
  [https://gist.github.com/anonymous/df811ff4f1aec422e44d](https://gist.github.com/anonymous/df811ff4f1aec422e44d)
  another system.
  Regards,
  Derek
        Hi Derek,
        "all".
        Anubhav
              Hi Anubhav,
              "30": "RUNNING",
                  "fw_id": 30,
                  "created_on":
        (I ran the
        it if it's helpful.
              Regards,
              Derek
                    Hi Derek,
        "READY"
                   [https://pythonhosted.org/FireWorks/reference.html#interpretation-of-state-o](https://pythonhosted.org/FireWorks/reference.html#interpretation-of-state-o)
        f-fws-and-wfs
        type the command:
                    Anubhav
                          them using:
        infinite --sleep 60
                          --maxjobs_queue 50
                          more.
                          514
        count
                          508
                          6
                          0
        fw_id | sort
                          "fw_id": 32,
                          "fw_id": 33,
                          "fw_id": 34,
                          "fw_id": 35,
                          "fw_id": 36,
                          "fw_id": 37,
                          [See
        fw_id 32.
                          32?  It appears not:
        still no luck:
        rerun_fws -i 32
        try/check/examine?
                          Thank you,
                          Derek
Hi Anubhav,
Well, my workflow didn't fail in the same spot, so reproducibility isn't deterministic. Some interesting things I've noticed:
514
# So all jobs completed
lpad get\_wflows \-s RUNNING \{ &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&quot;name&quot;: &quot;unnamed WF\-\-1&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&quot;state&quot;: &quot;RUNNING&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&quot;states\_list&quot;: &quot;C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\- C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\- C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&quot;created\_on&quot;: &quot;2015\-09\-17T02:08:13\.284000&quot; \} \# Assuming C means COMPLETED, it looks like everything is done\. \# However: lpad get_wflows -s RUNNING -d all | grep RUNNING
         "20": "RUNNING",
         "29": "RUNNING",
         "56": "RUNNING",
         "110": "RUNNING",
         "83": "RUNNING",
         "65": "RUNNING",
         "94": "RUNNING",
         "11": "RUNNING",
     "state": "RUNNING",
So it looks like maybe there's some inconsistency between "lpad get_wflows" calls, depending on the options passed? Maybe that narrows down the culprit?
If we think that caching is a problem, is there a way to disable it in order to verify that?
Derek
On Wed, 16 Sep 2015, Anubhav Jain wrote:
Hi Derek,
Examining the changelog (https://pythonhosted.org/FireWorks/changelog.html), I don't see anything past 1.04 that would have affected this issue one way or the other. So if you are seeing it
Anubhav
      Regards,
      Derek
            Hi Derek,
            Anubhav
             Hi Anubhav,
             another system.
             Regards,
             Derek
             Hi Derek,
             "all".
             Anubhav
             Hi Anubhav,
             "30": "RUNNING",
             "fw_id": 30,
             "created_on":
             (I ran the
             it if it's helpful.
             Regards,
             Derek
             Hi Derek,
             "READY"
             f-fws-and-wfs
             type the command:
             Anubhav
             them using:
             infinite --sleep 60
             --maxjobs_queue 50
             more.
             count
             508
             0
             fw_id | sort
             "fw_id": 32,
             "fw_id": 33,
             "fw_id": 34,
             "fw_id": 35,
             "fw_id": 36,
             "fw_id": 37,
             [See
             fw_id 32.
             32? It appears not:
             still no luck:
             rerun_fws -i 32
             try/check/examine?
             Thank you,
             Derek
Hi Derek,
I think it is related to the same issue I mentioned before, i.e. the caching. You can disable it by modifying the code - there is a get_wf_by_fw_id_lzyfw() method. Change the contents of the method to be the same as get_wf_by_fw_id(). Then it won’t use the “LazyFireWork” which has the caching.
But I think it is best if you can send a runnable example. It doesn’t need to be 100% reproducible, even if it fails 25% of the time it is enough that we can at least try to debug. Otherwise we are stuck.
Anubhav
On Thu, Sep 17, 2015 at 12:52 PM, Derek [email protected] wrote:
Hi Anubhav,
Well, my workflow didn’t fail in the same spot, so reproducibility isn’t deterministic. Some interesting things I’ve noticed:
514
514
$ lpad get_wflows -s RUNNING
"name": "unnamed WF--1",
"state": "RUNNING",
"states_list": "C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-
C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-
C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C-C",
"created_on": "2015-09-17T02:08:13.284000"
Assuming C means COMPLETED, it looks like everything is done.
However:
$ lpad get_wflows -s RUNNING -d all | grep RUNNING
    "20": "RUNNING",
    "29": "RUNNING",
    "56": "RUNNING",
    "110": "RUNNING",
    "83": "RUNNING",
    "65": "RUNNING",
    "94": "RUNNING",
    "11": "RUNNING",
"state": "RUNNING",
So it looks like maybe there’s some inconsistency between “lpad get_wflows” calls, depending on the options passed? Maybe that narrows down the culprit?
Derek
Hi Derek,
Anubhav
  Regards,
  Derek
        Hi Derek,
        Anubhav
              Hi Anubhav,
              another system.
              Regards,
              Derek
                    Hi Derek,
                    "all".
                    Anubhav
                          Hi Anubhav,
                          "30": "RUNNING",
                              "fw_id": 30,
                              "created_on":
                    (I ran the
                    it if it's helpful.
                          Regards,
                          Derek
                                Hi Derek,
                    "READY"
                    f-fws-and-wfs
                    type the command:
                                Anubhav
                                      them using:
                    infinite --sleep 60
                                      --maxjobs_queue 50
                                      more.
                                      514
                    count
                                      508
                                      6
                                      0
                    fw_id | sort
                                      "fw_id": 32,
                                      "fw_id": 33,
                                      "fw_id": 34,
                                      "fw_id": 35,
                                      "fw_id": 36,
                                      "fw_id": 37,
                                      [See
                    fw_id 32.
                                      32?  It appears not:
                    still no luck:
                    rerun_fws -i 32
                    try/check/examine?
                                      Thank you,
                                      Derek
Also, it would be helpful if you can indicate some details of your workflow. e.g., are you using any dynamic FWActions?
Anubhav
On Fri, Sep 18, 2015 at 11:15 AM, Anubhav Jain [email protected] wrote:
Hi Derek,
Anubhav
Hi Anubhav,
514
514
"state": "RUNNING",
However:
    "20": "RUNNING",
    "29": "RUNNING",
    "56": "RUNNING",
    "110": "RUNNING",
    "83": "RUNNING",
    "65": "RUNNING",
    "94": "RUNNING",
    "11": "RUNNING",
"state": "RUNNING",
Derek
Hi Derek,
Anubhav
  Regards,
  Derek
        Hi Derek,
        Anubhav
              Hi Anubhav,
              another system.
              Regards,
              Derek
                    Hi Derek,
                    "all".
                    Anubhav
                          Hi Anubhav,
                          "30": "RUNNING",
                              "fw_id": 30,
                              "created_on":
                    (I ran the
                    it if it's helpful.
                          Regards,
                          Derek
                                Hi Derek,
                    "READY"
                    f-fws-and-wfs
                    type the command:
                                Anubhav
                                      them using:
                    infinite --sleep 60
                                      --maxjobs_queue 50
                                      more.
                                      514
                    count
                                      508
                                      6
                                      0
                    fw_id | sort
                                      "fw_id": 32,
                                      "fw_id": 33,
                                      "fw_id": 34,
                                      "fw_id": 35,
                                      "fw_id": 36,
                                      "fw_id": 37,
                                      [See
                    fw_id 32.
                                      32?  It appears not:
                    still no luck:
                    rerun_fws -i 32
                    try/check/examine?
                                      Thank you,
                                      Derek
Also, another way to confirm that the caching is the problem is to inspect the MongoDB.
i) Connect to MongoDB
ii) Look at the workflows collection inside your fireworks database
iii) Examine the “wf_states” key, and see if you find any discrepancies between that and the fireworks data.
But again, sending an example is the only way to really debug this.
Anubhav
Hi Derek,
Anubhav
Hi Anubhav,
514
514
"state": "RUNNING",
However:
    "20": "RUNNING",
    "29": "RUNNING",
    "56": "RUNNING",
    "110": "RUNNING",
    "83": "RUNNING",
    "65": "RUNNING",
    "94": "RUNNING",
    "11": "RUNNING",
"state": "RUNNING",
Derek
Hi Derek,
Anubhav
  Regards,
  Derek
        Hi Derek,
        Anubhav
              Hi Anubhav,
              another system.
              Regards,
              Derek
                    Hi Derek,
                    "all".
                    Anubhav
                          Hi Anubhav,
                          "30": "RUNNING",
                              "fw_id": 30,
                              "created_on":
                    (I ran the
                    it if it's helpful.
                          Regards,
                          Derek
                                Hi Derek,
                    "READY"
                    f-fws-and-wfs
                    type the command:
                                Anubhav
                                      them using:
                    infinite --sleep 60
                                      --maxjobs_queue 50
                                      more.
                                      514
                    count
                                      508
                                      6
                                      0
                    fw_id | sort
                                      "fw_id": 32,
                                      "fw_id": 33,
                                      "fw_id": 34,
                                      "fw_id": 35,
                                      "fw_id": 36,
                                      "fw_id": 37,
                                      [See
                    fw_id 32.
                                      32?  It appears not:
                    still no luck:
                    rerun_fws -i 32
                    try/check/examine?
                                      Thank you,
                                      Derek
Ok, I'll try and produce a shareable version that reproduces the behavior.
I'm not doing anything fancy like dynamic FWActions. Data gets passed between Fireworks and their FireTasks through (predetermined) files.
Derek
iii) Examine the "wf_states" key, and see if you find any discrepancies between that and the fireworks data.
      FWActions?
Anubhav
On Fri, Sep 18, 2015 at 11:15 AM, Anubhav Jain <[email protected]> wrote:
      Hi Derek,
get_wf_by_fw_id(). Then it won't use the "LazyFireWork" which has the caching.
*But* I think it is best if you can send a runnable example. It doesn't need to be 100% reproducible, even if it
Anubhav
On Thu, Sep 17, 2015 at 12:52 PM, Derek <[email protected]> wrote:
      Hi Anubhav,
       lpad get\_fws \-d count &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;514 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; lpad get_fws -s COMPLETED -d count
      514
       lpad get\_wflows \-s RUNNING &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;\{ &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &quot;name&quot;: &quot;unnamed WF\-\-1&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &quot;state&quot;: &quot;RUNNING&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &quot;states\_list&quot;: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&quot;C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\- &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\- &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &quot;created\_on&quot;: &quot;2015\-09\-17T02:08:13\.284000&quot; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;\} &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;\# Assuming C means COMPLETED, it looks like everything is done\. &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;\# However: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; lpad get_wflows -s RUNNING -d all | grep RUNNING
       "20": "RUNNING",
       "29": "RUNNING",
       "56": "RUNNING",
       "110": "RUNNING",
       "83": "RUNNING",
       "65": "RUNNING",
       "94": "RUNNING",
       "11": "RUNNING",
       "state": "RUNNING",
      Derek
            Hi Derek,
            are seeing it
            Anubhav
            changed since then?
            1.1.3. If it
            you.
             Regards,
             Derek
             Hi Derek,
             Anubhav
             Hi Anubhav,
             another system.
             Regards,
             Derek
             Hi Derek,
             "all".
             Anubhav
             Hi Anubhav,
             "30": "RUNNING",
             "fw_id": 30,
             "created_on":
             (I ran the
             it if it's helpful.
             Regards,
             Derek
             Hi Derek,
             "READY"
             f-fws-and-wfs
             type the command:
             Anubhav
             them using:
             infinite --sleep 60
             --maxjobs_queue 50
             more.
             count
             508
             0
             fw_id | sort
             "fw_id": 32,
             "fw_id": 33,
             "fw_id": 34,
             "fw_id": 35,
             "fw_id": 36,
             "fw_id": 37,
             [See
             fw_id 32.
             32? It appears not:
             still no luck:
             rerun_fws -i 32
             try/check/examine?
             Thank you,
             Derek
Hi Derek,
One of the FWS developer noted a problem in WFLock that might be causing your issue. A fix is in v1.1.7, the latest version.
Some things you can try:
  • v1.1.7 should hopefully run your workflows reliably without problem
  • If there are problems, the “lpad detect_lostruns” command should be able to detect inconsistent workflows. Furthermore, you can fix them using “lpad detect_lostruns --refresh”. This should fix any workflows from previous FWS versions, but hopefully this should not be needed in v1.1.7.
Anubhav
On Friday, September 18, 2015 at 10:12:48 AM UTC-7, Derek wrote:
Ok, I’ll try and produce a shareable version that reproduces the
behavior.
I’m not doing anything fancy like dynamic FWActions. Data gets
Derek
  FWActions?
Anubhav
  Hi Derek,
Anubhav
  Hi Anubhav,
  514
  514
      "state": "RUNNING",
      "states_list":
  # Assuming C means COMPLETED, it looks like everything is done.
  # However:
          "20": "RUNNING",
          "29": "RUNNING",
          "56": "RUNNING",
          "110": "RUNNING",
          "83": "RUNNING",
          "65": "RUNNING",
          "94": "RUNNING",
          "11": "RUNNING",
      "state": "RUNNING",
  Derek
        Hi Derek,
        Examining the changelog ([https://pythonhosted.org/FireWorks/changelog.html](https://pythonhosted.org/FireWorks/changelog.html)), I don't see
        are seeing it
        Anubhav
        On Wed, Sep 16, 2015 at 9:36 AM, Derek <[email protected]> >  > >             wrote:
        changed since then?
        1.1.3.  If it
        you.
              Regards,
              Derek
                    Hi Derek,
                    Anubhav
                    On Tue, Sep 15, 2015 at 3:13 PM, Derek >  > >                         <[email protected]> wrote:
                          Hi Anubhav,
                          another system.
                          Regards,
                          Derek
                                Hi Derek,
                                "all".
                                Anubhav
                                On Tue, Sep 15, 2015 at 10:26 AM, Derek >  > >                                     <[email protected]> wrote:
                                      Hi Anubhav,
                                      "30": "RUNNING",
                                          "fw_id": 30,
                                          "created_on":
                                (I ran the
                                it if it's helpful.
                                      Regards,
                                      Derek
                                            Hi Derek,
                                "READY"
                                f-fws-and-wfs
                                type the command:
                                            Anubhav
                                            On Monday, September 14, 2015 at >  > >                                     11:05:01 AM UTC-7, Derek wrote:
                                                  them using:
                                infinite --sleep 60
                                                  --maxjobs_queue 50
                                                  more.
                                                  514
                                count
                                                  508
                                                  6
                                                  0
                                fw_id | sort
                                                  "fw_id": 32,
                                                  "fw_id": 33,
                                                  "fw_id": 34,
                                                  "fw_id": 35,
                                                  "fw_id": 36,
                                                  "fw_id": 37,
                                                  [See
                                fw_id 32.
                                                  32?  It appears not:
                                still no luck:
                                rerun_fws -i 32
                                try/check/examine?
                                                  Thank you,
                                                  Derek
Ok, I'll try this out and report back. Apologies that I haven't had time to pursue the debugging further.
Regards,
Derek
On Wed, 21 Oct 2015, Anubhav Jain wrote:
Hi Derek,
* v1.1.7 should hopefully run your workflows reliably without problem
* If there are problems, the "lpad detect_lostruns" command should be able to detect inconsistent workflows. Furthermore, you can fix them using "lpad detect_lostruns --refresh". This should fix
Anubhav
      behavior.
      Derek
      > Also, another way to confirm that the caching is the problem is to inspect the MongoDB.
      > i) Connect to MongoDB
      > ii) Look at the workflows collection inside your fireworks database
      > iii) Examine the "wf_states" key, and see if you find any discrepancies between that and the fireworks data.
      > But again, sending an example is the only way to really debug this.
      > On Fri, Sep 18, 2015 at 11:21 AM, Anubhav Jain <[email protected]> wrote:
      > Also, it would be helpful if you can indicate some details of your workflow. e.g., are you using any dynamic
      > FWActions?
      > Best,
      > Anubhav
      > On Fri, Sep 18, 2015 at 11:15 AM, Anubhav Jain <[email protected]> wrote:
      > Hi Derek,
      > I think it is related to the same issue I mentioned before, i.e. the caching. You can disable it by modifying
      > the code - there is a get_wf_by_fw_id_lzyfw() method. Change the contents of the method to be the same as
      > get_wf_by_fw_id(). Then it won't use the "LazyFireWork" which has the caching.
      > *But* I think it is best if you can send a runnable example. It doesn't need to be 100% reproducible, even if it
      > fails 25% of the time it is enough that we can at least try to debug. Otherwise we are stuck.
      > Best,
      > Anubhav
      > On Thu, Sep 17, 2015 at 12:52 PM, Derek <[email protected]> wrote:
      > Hi Anubhav,
      > Well, my workflow didn't fail in the same spot, so reproducibility isn't deterministic. Some
      > interesting things I've noticed:
      > lpad get\_fws \-d count &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; 514 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad get_fws -s COMPLETED -d count
      > 514
      > # So all jobs completed
      > lpad get\_wflows \-s RUNNING &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; \{ &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;name&quot;: &quot;unnamed WF\-\-1&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;state&quot;: &quot;RUNNING&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;states\_list&quot;: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\- &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\- &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C\-C&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;created\_on&quot;: &quot;2015\-09\-17T02:08:13\.284000&quot; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; \} &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; \# Assuming C means COMPLETED, it looks like everything is done\. &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; \# However: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad get_wflows -s RUNNING -d all | grep RUNNING
      > "20": "RUNNING",
      > "29": "RUNNING",
      > "56": "RUNNING",
      > "110": "RUNNING",
      > "83": "RUNNING",
      > "65": "RUNNING",
      > "94": "RUNNING",
      > "11": "RUNNING",
      > "state": "RUNNING",
      > So it looks like maybe there's some inconsistency between "lpad get_wflows" calls, depending on the
      > options passed? Maybe that narrows down the culprit?
      > If we think that caching is a problem, is there a way to disable it in order to verify that?
      > Thanks,
      > Derek
      > On Wed, 16 Sep 2015, Anubhav Jain wrote:
      > Hi Derek,
      > Examining the changelog (https://pythonhosted.org/FireWorks/changelog.html), I don't see
      > anything past 1.04 that would have affected this issue one way or the other. So if you
      > are seeing it
      > in 1.04 chances are that you will still see it in 1.1.3.
      > Best,
      > Anubhav
      > On Wed, Sep 16, 2015 at 9:36 AM, Derek <[email protected]> > > wrote:
      > I experienced this bug using fireworks version 1.04. Has any of the caching code
      > changed since then?
      > I'm happy to go through the git logs myself if I know which files to look in.
      > I'm going to first rerun my entire workflow (using version 1.04) and see how
      > reproducible the behavior is. If it is perfectly reproducible, I'll try it again in
      > 1.1.3. If it
      > reproduces there, I'll make a bunch of test/dummy jobs and share that code with
      > you.
      > Regards,
      > Derek
      > On Tue, 15 Sep 2015, Anubhav Jain wrote:
      > Hi Derek,
      > Indeed, having a dummy workflow (with test tasks or with sleep tasks) that
      > we can reproduce in its entirety would be ideal.
      > Best,
      > Anubhav
      > On Tue, Sep 15, 2015 at 3:13 PM, Derek > > <[email protected]> wrote:
      > Hi Anubhav,
      > Here is a gist for the output of "lpad get_wflows -i 32 -d all":
      > get_wflows_all.txt · GitHub
      > The workflow that I submitted uses a bunch of external (to
      > python) dependencies, so maybe not the easiest to replicate on
      > another system.
      > I could try to make a dummy workflow where the firetasks are
      > sleep commands--that would be portable. What exactly do you
      > have in mind? I'm guessing this could be a timing-related
      > issue, but beyond that I'm not sure.
      > Regards,
      > Derek
      > Hi Derek,
      > Thanks for reporting this - there is a potential for
      > the FW and WFlow states to not match; this is
      > because a contributor had pushed a change to cache
      > the FW states inside the WFlow to speed up the
      > overall operation of
      > FWS. This causes the storage of FW and WFlow states
      > to be separate. Unfortunately, if there is a bug in
      > this code, it would cause the problems that you see.
      > Do you happen to have any code example I can use to
      > reproduce this problem? Then I can include it as a
      > unit test and ask the contributor to fix it. We
      > already have a basic unit test for this
      > functionality and it passes,
      > so I need an example of how to force a failure.
      > Also, if the "-all" option is too long, you can also
      > use "lpad get_wflows -i 31 -d more" which will
      > provide more information but not nearly as much as
      > "all".
      > Best,
      > Anubhav
      > On Tue, Sep 15, 2015 at 10:26 AM, Derek > > <[email protected]> wrote:
      > Hi Anubhav,
      > Using lpad get_wflows, I see that one of the
      > other dependencies for fw_id 32, fw_id 30, is still
      > RUNNING according to:
      > lpad get\_wflows \-i 32 \-d all | grep &#39;&quot;30&quot;&#39; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;30&quot;: &quot;RUNNING&quot;, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; However, lpad get\_fws shows it as COMPLETED: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad get_fws -i 30
      > "name": "Unnamed FW",
      > "fw_id": 30,
      > "state": "COMPLETED",
      > "created_on":
      > "2015-09-10T16:45:38.431775",
      > "updated_on": "2015-09-10T16:52:00.453871"
      > The associated launcher_* for fw_id 30
      > directory has an empty .error file and a .out file
      > indicating that the Rocket finished and completed.
      > The output that the job produced also looks correct
      > (I ran the
      > command manually and the results match).
      > It seems odd that get_wflows and get_fws show
      > different states for same job.
      > Happy to provide more info as necessary. The
      > "-d all" option for lpad get_wflows produces a lot
      > of output (it's a big workflow), but I can include
      > it if it's helpful.
      > Regards,
      > Derek
      > On Mon, 14 Sep 2015, Anubhav Jain wrote:
      > Hi Derek,
      > The "WAITING" state indicates that there
      > is a job dependency, i.e. a parent job that the
      > current job is waiting to be COMPLETED. Those FWs
      > will not be picked up by rlaunch or qlaunch. Only
      > "READY"
      > jobs are set to be run.
      > See a description of states here:
      > https://pythonhosted.org/FireWorks/reference.html#interpretation-of-state-o
      > f-fws-and-wfs
      > Next, you probably want to try to debug
      > why the FW is not READY yet. One thing you can try
      > is querying the state of all the jobs within the
      > workflow of the affected FW, e.g.:
      > lpad get_wflows -i 31
      > where "31" is the id of one of your
      > affected FWS. This should print out a report of all
      > states in your workflow and you can probably see
      > immediately where things got stuck.
      > If things are still not clear after that
      > and you are confident that something might be wrong,
      > type the command:
      > lpad get_wflows -i 31 -d all
      > and paste the result back into this list
      > so I can take a look at all the links in the
      > workflow and what is happening.
      > Best,
      > Anubhav
      > On Monday, September 14, 2015 at > > 11:05:01 AM UTC-7, Derek wrote:
      > Hello,
      > Over the weekend I submitted just
      > over 500 jobs to Fireworks
      > (this is the largest pipeline I've
      > tried to date) and executed
      > them using:
      > qlaunch -r rapidfire --nlaunches
      > infinite --sleep 60
      > --maxjobs_queue 50
      > All but 6 of them completed
      > successfully and I'm trying to figure
      > out what's happened with those 6.
      > If I try "qlaunch" or
      > "rlaunch", neither command
      > recognizes that there are few jobs
      > left to complete. For example:
      > qlaunch \-r singleshot &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; 2015\-09\-14 10:47:45,974 INFO No &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; jobs exist in the LaunchPad for &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; submission to queue\! &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; Here are some \(hopefully\) relevant &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; details\. I&#39;m happy to provide &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; more\. &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad get_fws -d count
      > 514
      > lpad get\_fws \-s COMPLETED \-d &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; count &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; 508 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad get_fws -s WAITING -d count
      > 6
      > lpad get\_fws \-s FIZZLED \-d count &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; 0 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; Which Fireworks are waiting? &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad get_fws -s WAITING | grep
      > fw_id | sort
      > "fw_id": 32,
      > "fw_id": 33,
      > "fw_id": 34,
      > "fw_id": 35,
      > "fw_id": 36,
      > "fw_id": 37,
      > What was Firework with fw_id 31,
      > and what happend to it?
      > lpad get\_fws \-i 31 \-d more &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; \[See &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; https://gist.github.com/anonymous/10ea08044f574d190625\] &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; Looking in the launch directory &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; for fw\_id 31 \(and looking at the &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; yaml file I used to submit my &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; workflow\), I know that the Firework &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; with fw\_id 31 should be \(as far as &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; I can tell\) the only &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; dependency for the Firework with &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; fw\_id 32\. &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; Was a launch directory ever &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; created for the Firework with fw\_id &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; 32? It appears not: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; grep -rl '"fw_id": 32,' ./*
      > &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; \(the same is true for the other &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &quot;waiting&quot; Fireworks\) &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; If I try to rerun these Firworks, &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; still no luck: &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&gt; lpad rerun_fws -i 32$ lpad
      > rerun_fws -i 32
      > 2015-09-14 10:50:56,652 INFO
      > Finished setting 1 FWs to rerun
      > $ qlaunch -r singleshot
      > 2015-09-14 10:52:37,092 INFO No
      > jobs exist in the LaunchPad for
      > submission to queue!
      > Is there anything else I should
      > try/check/examine?
      > Thank you,
      > Derek
      > PS: Apologies that this post also
      > got appended to my previous
      > "qluanching dependent jobs" thread
