Firs time installation: Errors while running "lpad reset"
After the first time installation of the atomate package, i tried running “lpad reset”.
And i am getting following error message.
Any suggestions on how can i overcome this and start using atomate.
Also, if i prefer to run VASP on a local machine(without any Queueing system), how do i set up my_qadapter.yaml file in that case?
I will appreciate any help on this.
Error Message:
raceback (most recent call last):
File “/home/kapil/atomate/atomate_env/bin/lpad”, line 10, in
sys.exit(lpad())
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/fireworks/scripts/lpad_run.py”, line 1173, in lpad
args.func(args)
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/fireworks/scripts/lpad_run.py”, line 163, in reset
lp.workflows.count()))[0].upper() == ‘Y’:
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/pymongo/collection.py”, line 1779, in count
return self._count(cmd, collation, session)
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/pymongo/collection.py”, line 1574, in _count
with self._socket_for_reads(session) as (sock_info, slave_ok):
File “/usr/lib/python3.6/contextlib.py”, line 81, in enter
return next(self.gen)
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1135, in _socket_for_reads
server = topology.select_server(read_preference)
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/pymongo/topology.py”, line 226, in select_server
address))
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/pymongo/topology.py”, line 184, in select_servers
selector, server_timeout, address)
File “/home/kapil/atomate/atomate_env/lib/python3.6/site-packages/pymongo/topology.py”, line 200, in _select_servers_loop
self._error_message(selector))
pymongo.errors.ServerSelectionTimeoutError: connection closed
Kapil
Hi Kapil,
This error message usually means that your my_launchpad.yaml file is not configured correctly. Please check that the URL/port and authentication information (particularly for the admin user, in this case) are set up correctly.
If you want to run VASP locally, you should use “rlaunch” commands instead of “qlaunch”, e.g. “rlaunch singleshot” or “rlaunch rapidfire”. If you are not using “qlaunch” to launch through a queue, it doesn’t matter how “my_qadapter.yaml” is configured as it won’t be used.
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
Hi Brandon,
Thank you for your prompt reply to my query.
I will try to follow your suggestions.
Kapil
On Wednesday, 5 June 2019 14:25:14 UTC+5:30, Brandon B wrote:
Hi Kapil,
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
Hi all,
I am facing a very similar situation as described in this post while trying to install atomate onto my institution’s HPC resources. Specifically, I received an error when running ‘lpad reset’:
File “/home/lowt/leex7132/.local/bin/lpad”, line 11, in
sys.exit(lpad())
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py”, line 1176, in lpad
args.func(args)
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py”, line 163, in reset
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/pymongo/collection.py”, line 1779, in count
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/pymongo/collection.py”, line 1574, in _count
File “/panfs/roc/msisoft/anaconda/anaconda3-2018.12/lib/python3.7/contextlib.py”, line 112, in enter
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/pymongo/mongo_client.py”, line 1135, in _socket_for_reads
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/pymongo/topology.py”, line 226, in select_server
address))
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/pymongo/topology.py”, line 184, in select_servers
File “/home/lowt/leex7132/.local/lib/python3.7/site-packages/pymongo/topology.py”, line 200, in _select_servers_loop
pymongo.errors.ServerSelectionTimeoutError: connection closed,connection closed,connection closed
I’ve tried Brandon’s advise but could not spot any mistake in my_launchpad.yaml file. The file content is shown below:
host: mongodb+srv://heterostructuredatabase-sdtzx.mongodb.net
port: 27017
username: admin_username
password: admin_password
ssl_ca_certs: null
logdir: null
strm_lvl: INFO
user_indices:
wf_user_indices:
To provide more context on my setup, I created a free version of MongoDB Atlas database and was able to connect to the database through my local machine via mongo shell (using my admin username and password). I have also found out that there is no firewall blocking the connection between MongoDB server and my institution’s HPC resource.
Any help would be very appreciated.
Thank you.
Eng Hock
On Wednesday, June 5, 2019 at 3:57:01 AM UTC-5, Kapil Gupta wrote:
Hi Brandon,
Kapil
Hi Kapil,
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
Can you tell me the output of :
lpad version
i.e. which version of FWS you have installed
On Wednesday, August 7, 2019 at 6:32:51 PM UTC-7, Eng Hock Lee wrote:
Hi all,
sys.exit(lpad())
args.func(args)
address))
port: 27017
ssl_ca_certs: null
logdir: null
strm_lvl: INFO
user_indices:
wf_user_indices:
Thank you.
Eng Hock
Hi Brandon,
Kapil
Hi Kapil,
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
Also I’d say:
  • first look at “lpad version” (I want to make sure you have the latest FWS installed - we fixed some connection issues back in ~v1.9.0 or so)
  • second try connecting using a my_launchpad.yaml file in your localhost, i.e. connecting from your localhost to the database via Fireworks (rather than from your computing center)
  • third, see if you can use the uri_mode instead of the other parameters
e.g.
my_launchpad.yaml
host: <<MongoDB URI from https://docs.mongodb.com/manual/reference/connection-string/>>
uri_mode: true
lpad version
Hi all,
sys.exit(lpad())
args.func(args)
address))
port: 27017
ssl_ca_certs: null
logdir: null
strm_lvl: INFO
user_indices:
wf_user_indices:
Thank you.
Eng Hock
Hi Brandon,
Kapil
Hi Kapil,
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
Hi Anubhav,
Thank you for your assistance. I was able to connect to the database using the uri_mode you mentioned. If it is still relevant, my lpad version is 1.9.4.
Thank you!
Eng Hock
On Friday, August 9, 2019 at 6:01:45 PM UTC-5, Anubhav Jain wrote:
Also I’d say:
e.g.
my_launchpad.yaml
uri_mode: true
lpad version
Hi all,
sys.exit(lpad())
args.func(args)
address))
port: 27017
ssl_ca_certs: null
logdir: null
strm_lvl: INFO
user_indices:
wf_user_indices:
Thank you.
Eng Hock
Hi Brandon,
Kapil
Hi Kapil,
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
Ok
If you want to try without URI mode, I would also try setting:
ssl: True
authsource: admin
in your my_launchpad.yaml. It’s possible one of those could also fix it.
On Saturday, August 10, 2019 at 6:27:24 PM UTC-7, Eng Hock Lee wrote:
Hi Anubhav,
Thank you!
Eng Hock
Also I’d say:
e.g.
my_launchpad.yaml
uri_mode: true
lpad version
Hi all,
sys.exit(lpad())
args.func(args)
address))
port: 27017
ssl_ca_certs: null
logdir: null
strm_lvl: INFO
user_indices:
wf_user_indices:
Thank you.
Eng Hock
Hi Brandon,
Kapil
Hi Kapil,
Cheers,
Brandon
Error Message:
sys.exit(lpad())
args.func(args)
address))
Kapil
