I have two gpus in a linux box and I did nvc_get_devices and both are
seen as Device 0 and Device 1 respectively. I tried to run two
different simulations at the same time and changed the input files of
each run as "fix 0 all gpu force/neigh 0 0 -1.0" and "fix 0 all gpu
force/neigh 1 1 -1.0" hoping to assign one simulation to Device 0 and
the other to Device 1. This doesn't seem to work. And, If I ran the
simulation with "fix 0 all gpu force/neigh 1 1 -1.0", the gpu used by
the run is Device 0 and not Device 1. I used nvidia-smi to track GPU
utilization. My cuda version is 3.2.
Is there a way to effectively choose which GPU the simulation will use?
Jan-Michael
do you use the latest version of LAMMPS?
there was a bug in the gpu code and i think it has been fixed since.
you can search the mailing list archives.
Hi Jan-Michael
I think the fix for the issue you are running into is here: http://lammps.sandia.gov/threads/msg19380.html
BTW, You shouldn't run into this issue with the GPU library update from my site. If you do, let me know.
- Mike
Jan-Michael Carrillo wrote:
Mike,Steve and Axel;
I updated the Apr 29,2011 version using gpu_package.tar.gz from Mike's
website. The change in lib/gpu/pair_gpu_device.cpp for the variable
my_gpu was done during the update. This is similar to the link that
Axel showed me. The update now assigns the gpu correctly and my
simulations are running.
However, when I downloaded the May 2 version of lammps from the
sandia website (not the patch) and I tried to compile the gpu library,
I get an error: " No rule to make target `nv_kernel_def.h' needed by
`pair_gpu_atom.o'" when I type the command make -f Makefile.linux in
the /lammps/lib/gpu directory. I suspect that the May 2 version was
not packaged properly.
-Jan Michael
I'll let Mike answer this and make any changes he suggests.
There were some missing files in that patch (my fault) which Mike
alerted me to. So an addendum 4May patch came out yesterday.
See if that fixes this problem?
