Dear LAMMPS users,
I am using “fix adapt” in my simulations, I have two types of atoms in my system. Interactions between atom types 1 &1 are through buckingham potential and interactions between 1& 2 are through gauss type and there is no interactions between atom types 2 & 2.
I have mentioned the same thing in my input file as:
pair_style hybrid/overlay buck/coul/long 12.0 gauss 12.0
kspace_style pppm 1.0e-4
pair_coeff * * none
pair_coeff 1 1 buck/coul/long 31615.1 0.3025 647.8
pair_coeff 1 2 gauss 6.2673 0.9
With these settings I am getting the error “ERROR: Fix adapt pair style param not supported (…/fix_adapt.cpp:208)”
I am able to run some simulations with “fix adapt” using lj/cut i.e., “pair_style hybrid/overlay lj/cut 10 coul/cut 10 gauss 10” with out any errors. If I use buckingham potential I am getting the above mentioned error. Can “fix adapt” handle buckingham potential or it has any limitations? How can I overcome this problem.
Thank you in advance.
Dear LAMMPS users,
I am using "fix adapt" in my simulations, I have two types of atoms in
pair_coeff * * none
With these settings I am getting the error "ERROR: Fix adapt pair style
param not supported (../fix_adapt.cpp:208)"
I am able to run some simulations with "fix adapt" using lj/cut i.e.,
"pair_style hybrid/overlay lj/cut 10 coul/cut 10 gauss 10" with out any
error. Can "fix adapt" handle buckingham potential or it has any
limitations?
you have the answer already given yourself. to make fix adapt work for
a specific parameter, access to it needs to be programmed into the
corresponding style. if it is not, you get the error message that you
have seen.
you need to implement the suitable changes into the extract() method
of the corresponding pair style. plain and simple.
