I looked at the dump files. My commands are as follows and I ran the simulation for a short time.
fix deform all deform 1 x erate 0.000001 units box remap v
fix 2 all npt y 0 0 1000 z 0 0 1000 couple none temp ${temperature}
dump deform all custom 1 dump_deform.lammpstrj id mol mass x y z ix iy iz vx vy vz q fx fy fz
Now, I change remap v to remap x and I looked at the dump files. The velocities are the same if you had used the remap v option.
Check whether remap x works correctly:
Comment the following line in the above three lines but change remap v to remap x in fix deform.
Now I looked at the dump files. The velocities do not change as expected and the positions are transformed (affine transformation x=x0+vt, where v is the velocity of the moving boundary), This is in accordance with the manual.
However As I mentioned previously, when integration fixes are invoked and when fix deform is used with remap x option it gives the result as remap v option.
I can provide an input script if you want.
Thanks Dr. Steve for your response.
Arun
