Hi there,
I has a system modelled with ReaxFF, which will be minimized and equilibrated without electric fields. The electric field is only added after equilibration.
Will it be necessary to use the “fix_modify energy yes” with “fix efield 0 0 0” during minimization and equilibration, just to include the fictitious quantity into the potential energy?
Many thanks,
Catherine
Neither the fix not the fix_modify command would be needed if there is no field.
Hi Alex, thanks for your clarification. And I suppose after equilibriation, when field is added, the “fix_modify” is also not needed? Since there is no minimization going on and not calculating atom/pe for interest etc.
C
The command does what the documentation says it does. Whether you want that or not is your decision.
