Dear concerned, I have made a setup for surface-directed spinodal decomposition, where I have fluid in a simulation box with walls in XY plane at z=0, 128 in box units. The walls are amorphous and have a similar density as the fluid in between the walls. The system is periodic in the x and y directions. I imposed a freeze so that no atoms in the walls move. But somehow a fluid particle is percolating through the wall and it moves beyond the simulation box. I am trying to eliminate such percolation. So, I devised a way to avoid this. As soon as a fluid particle comes into the region of the wall, I assign its type as of the wall and again group them into wall identifiers and invoke fix freeze with those identifiers.
I can see, that as soon as fluid invades the wall, the script correctly assigns them wall type but after invoking freeze they still move. I could not understand why they are still moving. Below is the script for my setup.
units lj
atom_style atomic
boundary p p f
variable hightemp equal 2.0
variable lowtemp equal 1.0
variable AistoB equal 0.7
variable ens index 0
variable rnseed1 index 0
variable rnseed2 index 0
variable rnseed3 index 0
variable rnseed4 index 0
variable rnseed5 index 0
variable runsim equal 1200000
print "This is A = ${ens}"
#----neighbour table----------------#
#/communication
neighbor 0.1 bin
neigh_modify every 10 delay 0 check yes one 500000 page 5000000
#---------simulation box--------#
region box block 0 32 0 32 0 37
create_box 4 box
region fluid block 0 32 0 32 2.5 34.5
create_atoms 2 random 32768 ${rnseed1} fluid overlap 0.5
region LowerHalf block 0 32 0 32 0 2.0
region UperHalf block 0 32 0 32 35 37
create_atoms 3 random 2048 ${rnseed4} UperHalf overlap 0.9
create_atoms 4 random 2048 ${rnseed5} LowerHalf overlap 0.9
#delete_atoms region top
#delete_atoms region bottom
#--masses--#
mass * 1
#-------interaction Potential------#
pair_style hybrid lj/smooth/linear 2.5 table linear 10000
pair_coeff * * lj/smooth/linear 1.0 1.0 2.5
pair_coeff 1 2 lj/smooth/linear 0.5 1.0 2.5
pair_coeff 1 4 table wallLJ.table wall_ra
pair_coeff 2 4 table wallLJ.table wall_r 1.122462048
pair_coeff * 3 table wallLJ.table wall_r 1.122462048
#delete_atoms overlap 0.5 all all
#create groups
group Bottomwall type 4
group Topwall type 3
group A type 1
group B type 2
group AB type 1 2
velocity AB create ${hightemp} ${rnseed1} dist uniform
write_dump all atom dump.atom
#-------energy minimization---------#
fix freezeTop Topwall setforce 0 0 0
fix freezeBottom Bottomwall setforce 0 0 0
min_style sd
minimize 1.0e-10 1.0e3 1000000 1000000
#----------equib at T=2--------------#
timestep 0.001
fix 1 all nvt temp ${hightemp} ${hightemp} $(100*dt)
thermo 1000
thermo_style custom step temp pe etotal
dump 11 all custom 100 dumpTest.${ens} type x y z
run 1000
unfix 1
unfix freezeTop
unfix freezeBottom
set region LowerHalf type 4
set region UperHalf type 3
group A type 1
group B type 2
group AB type 1 2
thermo 1000
run 5000
unfix 1
unfix11
