Hi, I am trying to simulate competitive adsorption of a binary mixture of gas in a porous medium using GC+MD in LAMMPS. My system has a gas reservoir and a porous film. Number of molecules in the reservoir are controlled using gcmc and the time integrations are performed with fix rigid/nvt/small.
Relevant lines from my script are:
compute mdtemp gas temp
compute_modify mdtemp dynamic/dof yes
fix mygcmc1 gas gcmc 20000 10 0 0 987987 ${tem} ${mu} ${dis} region res mol co2mol pressure ${pr1} full_energy tfac_insert 2 rigid myrigid
fix myrigid gas rigid/nvt/small molecule temp ${tem} ${tem} ${Tdamp} mol co2mol
fix_modify myrigid temp mdtemp
fix_modify myrigid dynamic/dof yes
This works fine with a single molecule template (here co2mol). It seems that these two fixes only accept a single molecule template as input and they must match with each other. My question is- Is there any other way to maintain communication between fix gcmc and fix rigid/nvt/small using two or more molecule templates?
Any help would be appreciated. Thank you.
