Fix gcmc mc moves
Hello everyone,
I hope you’re doing well. I have a question regarding fix gcmc. I found that I can’t perform MC moves (translation, rotation, etc.) when using fix rigid or fix shake. I want to know if there is any workaround for this. In my case, I’m working in saturated conditions, where I don’t expect any insertion or deletion, but I still need MC moves for sampling.
Is there any solution for this? thank you for your help :slight_smile:
One solution, which is probably not what you were hoping for, is to use a true Monte Carlo code instead of LAMMPS, like Raspa or GOMC.
Thank you for your reply
I was keeping this as my last hope :cry:. If I may ask you, which one of these (RASPA, Towhee, GOMC) is the easiest to export/import data from LAMMPS? I was considering doing a hybrid approach.
I am currently combining GOMC and LAMMPS to perform efficient hybrid MC/MD simulations, and I had to write Python converters to go from LAMMPS .data to .pdb/.psf files. Its not difficult, but its definitely annoying. I know people that are using Raspa and LAMMPS similarly, and they also had to write their own converters. There may not exist an easy solution currently, although I don’t know anything about Towhee so may be there are smarter solutions out there.
Thank you very much for your help. I just have one last question: does GOMC support defining regions like LAMMPS?
I am not aware of that possibility, but I could be wrong. These Monte Carlo codes typically have (much) fewer options than LAMMPS, unfortunately.
Please note that you could use LAMMPS just as a “force engine” and drive the simulation with an external code using the MDI package or through the LAMMPS script/library interface. There are several examples bundled with LAMMPS, including a simple “MC driver”.
Thank you very much for your help , :pray:
