Fix langevin documentation
The manual has the following note for fix langevin:
This accumulated energy does NOT include kinetic energy removed by the zero flag. LAMMPS will print a warning when both options are active.
However, if I issue the command:
fix 1 all langevin 300. 300. $(100*dt) 185497 angmom 1.0 zero yes tally yes
No warning is issued. Has the option zero yes changed to conserve the kinetic energy?
Here is a minimal script to play with the fix.
test_langevin.in
# GayBerne ellipsoids in LJ background fluid
units        lj
atom_style   ellipsoid
dimension    2
lattice      sq 0.01
region       box block 0 20 0 20 -0.5 0.5
create_box   1 box
create_atoms 1 box
set          type 1 mass 1.0
set          type 1 shape 3 2 1
set          group all quat/random 18238
compute      rot all temp/asphere
velocity     all create 2.4 87287 loop geom
pair_style   gayberne 1.0 3.0 1.0 4.0
pair_coeff   1 1 1.5 3.0 0.4 0.8 1 0.4 0.8 1 2.5
neighbor     0.8 bin
thermo_style custom step c_rot epair etotal press vol
thermo       100
compute      0 all property/atom quatw quati quatj quatk shapex shapey shapez
dump        1 all custom 100 test_langevin.dump id type x y z c_0[*]
dump_modify 1 colname c_0[1] quatw colname c_0[2] quati colname c_0[3] quatj colname c_0[4] quatk &
              colname c_0[5] shapex colname c_0[6] shapey colname c_0[7] shapez
timestep     0.001
fix          1 all npt/asphere temp 2.0 2.0 0.1 iso 0.0 1.0 1.0 &
               mtk no pchain 0 tchain 1
fix          2 all enforce2d
# equilibrate to shrink box around dilute system
run          2000
# Check the option
unfix        1
fix          1 all nve/asphere
fix 3 all langevin 2.0 2.0 0.1 185497 angmom 1.0 zero yes tally yes
run          20000
From git log src/fix_langevin.cpp:
  commit 8020f5b9650f078c8aad2ec0c83cf67a02bd0901
  Author: Donatas Surblys <[email protected]>
  Date:   Thu Feb 14 18:54:59 2019 +0900
*     remove warning messages when using 'tally yes zero yes' with fix langevin
  commit b3a7a534a99b85c97b863f46c13684bf1422fbf2
      make fix langevin correctly account for energy with 'zero yes'
So, the answer is “yes” and the note from the documentation needs to be removed.
