Hi LAMMPS community,
I’m looking to implement a fix in the vein of bond/create and bond/delete that simply switches the bond type of certain bonds, rather than creating new bonds or deleting old ones. The method should:
- check to see if all bonds of type T between atom types itype and jtype are above a distance cutoff Rmin and below a cutoff Rmax
- change selected bonds to type T2 with a specified probability P
Is anyone aware of a preexisting method to carry this out? I’m thinking about creating a custom fix, since I imagine it won’t be a huge change from the bond/create and bond/delete fixes.
I’ve already implemented something similar with a looping method, creating new groups on distance criteria and using “set group x bond T2” commands, but this becomes unwieldy for multiple bond types to switch with different attempt rates. (The application requires three bond types with specified attempt rates for all 6 possible transitions).
Any ideas (or tips on editing LAMMPS source - my first time on that) are appreciated.
Ari
