Fix mscg and parallel use via MPI
I tried one of the examples provided by lammps in which the MSCG module is needed. The fix command of mscg is also in the input file. Below error massage showed up, I was wondering how I can fix the issue?
ERROR: Fix mscg does not yet support parallel use via MPI (…/fix_mscg.cpp:50)
Cheers,
Henrik
​please start by carefully reading the fix mscg documentation, especially
the "Restrictions" section.
(../fix_mscg.cpp:50)
​this message is quite self-explanatory as well.
axel.​
