Dear Lammps
I am performing the system of two parallel SiO2 walls are immersed in water. The system can goes well with NVT. (without minimize energy)
After NVT equilibrium, I use NPT for output properties. However, the volume of the system expended with time step. A very big empty hole formed after running NPT 100ps. Also, the two walls moved away from each other after NPT, although I used fix rigid on them.
Does anyone know why it happens like this? Below are the calculation for NVT and NPT.
NVT part
fix 1 water shake 0.0001 20 0 b 1 a 1
fix 2 water nvt temp $T $T 200.0
fix 3 wallup rigid/nvt single temp $T $T 200.0 force 1 off off off torque 1 off off off
fix 4 walllow rigid/nvt single temp $T $T 200.0 force 1 off off off torque 1 off off off
##NPT part
fix 2 water npt temp $T $T 100.0 z 1.0 1.0 100.0 dilate all
fix 3 wallup rigid/nvt single temp $T $T 100.0 force 1 off off off torque 1 off off off
fix 4 walllow rigid/nvt single temp $T $T 100.0 force 1 off off off torque 1 off off off
Thank you very much in advance.
Liyi
