please bear with me, this is my first posting here.
I am using LAMMPS (2 Aug 2023) and I want to print the info on the minimization behavior in a separate file, using fix print.
According to the manual this “Print a text string every N steps during a simulation run”, which in my reading would include a minimization run.
However, while the fix works for e.g. an NVE simulation it does not for quickmin.
if this is the intended way it should work, it would be helpful to update the documentation accordingly.
any suggestion, how I could still accomplish my goal?
Below is a code example to reproduce my problem.
Thanks a lot in advance for your help and patience!
Erik
atom_style atomic
lattice fcc 3.615
region box block 0 10 0 10 0 10
create_box 1 box
create_atoms 1 box
pair_style eam
pair_coeff 1 1 Cu_u3.eam
variable step equal step # Current step
variable epot equal pe # Potential energy
variable temp equal temp # Temperature
variable output_file string "test.eng"
fix engout all print 1 "${step} ${epot} ${temp}" file ${output_file} title "# step epot T"
velocity all create 30.0 376847 loop geom
fix 1 all nve
timestep 0.001
thermo 1
run 10
min_style quickmin
timestep 0.001
thermo 1
minimize 0 1e-10 100 100
