fix print - print pressure to file
Hi Users,
I’m trying to use the fix print to print the pressure of the system to a file “pressure.txt”, however, when I use the following commands:
variable sp equal press
fix stuff all print 1000 “$sp” file pressure.txt
I get the error:
ERROR on proc 0: Substitution for illegal variable
Any help would be appreciated!
Casey
Also, Steve, thanks for the log2txt.py!
You need ${sp} for a two-letter variable. See the variable
doc page.
