Fix reax/c/species
I’m trying to use this delete function as the one presented in the Lammps manual (fix reaxff/species command — LAMMPS documentation):
fix 1 all reaxff/species 1 100 100 species.out delete species.del masslimit 0 50
But, the version of lammps that I have only recognize the forcefield reax/c, and when I try to include the delete option:
fix 1 all reax/c/species 1 100 100 species.out delete species.del masslimit 0 50
I got this error:
ERROR: Illegal fix reax/c/species command (…/fix_reaxc_species.cpp:222)
Last command: fix 2 all reax/c/species 1 100 100 species.out delete species.del masslimit 0 100
Is there a way to do the delete option with reax/c??
Thanks!
Yes, but you must use the 3 August 2023 version or a more recent version of LAMMPS. This feature does not exist in older versions.
Your error message tells me that you are using a quite old version of LAMMPS (from 2021 or older).
