Hello, all.
I tried to make cascade simulation which contain several cascade in 1 simulation using loop.
Because the defect calculated by OVITO become too many as cascade increase, I guess this is come from system move due to cascade.
So I tried to use fix rencenter command before and after cascade to fix the system and compare defect.
But when I tried this, too many defects are derived even when comparing first cascade dump file.
Do you have any idea why this problem happen?
#-------------------------- Equlibration -----------------------------
reset_timestep 0
timestep 0.001
velocity all create ${TempEql} 4928456 rot yes dist gaussian
fix a all npt temp ${TempEql} ${TempEql} 100 iso 0.1 0.1 100
thermo 1000
thermo_style custom step temp etotal press vol density
run 50000
dump dumpNPT all custom 1000 dumpNPT*.data id type x y z
velocity all create ${TempEql} 491307 dist gaussian
fix 1 all nvt temp ${TempEql} ${TempEql} 0.1 #Relax at 300K
thermo 1000
thermo_style custom step dt time vol lx ly lz press pxx pyy pzz pe ke etotal temp
minimize 1e-8 1e-8 10000 10000
run ${NstpEql}
undump dumpNPT
unfix 1
fix center all recenter INIT INIT INIT units box
run 0
dump dumpinit all custom 1000 dumpPKA.0 id type x y z
reset_timestep 0
timestep 0.001
run 0
unfix center
undump dumpinit
This is script before cascade
# ------------------------ PKA SIMULATION ----------------------------
velocity PKA set ${pkaVx} ${pkaVy} ${pkaVz} units box
fix myNVE all nve
fix adtdt all dt/reset 1 1.0e-6 1.0e-3 0.01 units lattice
fix shell outeratom temp/rescale 1 ${TempEql} ${TempEql} 2 1
compute interT interatom temp
compute outerT outeratom temp
thermo 1000
thermo_style custom step dt time pe ke etotal temp c_interT c_outerT
thermo_modify line yaml format none
#dump DumpPKA all cfg 1000 DumpPKA${i}_*.cfg mass type xs ys zs id
#dump_modify DumpPKA element Ni Co Cr
run 40000
displace_atoms all move ${rshiftx} ${rshifty} ${rshiftz} units box
run 0
dump dumpPKA all custom 1000 dumpPKA.${i} id type x y z
run 0
unfix myNVE
unfix adtdt
unfix shell
unfix center
undump dumpPKA
write_restart restart.PKA_shot${i}
This is script for cascade simulation.
I compared dump file dumpPKA.0 and dumpPKA.1 for deriving defects.
