Thanks Ray. One more follow up question.
Can fix restraint be used with minimization
Does fix restraint command work in a similar fashion as the fix shake. For eg., in a specific case if i use the fix like the following with bond coefficient zero
fix holdem all restrain bond 45 48 0 0 2.75
From: “S Arun Srikant Sridhar” <[email protected]…1685…>
Date: Oct 25, 2014 10:30:20 PM
Subject: Re: [lammps-users] fix restrain command
To: Ray Shan <[email protected]…24…>
- Can fix restraint be used with minimization
Please see the doc page.
- Does fix restraint command work in a similar fashion as the fix shake. For eg., in a specific case if i use the fix like the following with bond coefficient zero
Look at the equation on the doc page and see for yourself what effect does it have if restraint coefficients are zero.
Ray
