I am simulating CO2 molecules with fix nvt/rigid/small molecule. For the initial case without any static framework, I am able to simulate it correctly with the defined fix.
The problem occurs when I define a fixed framework. After defining a static framework I get the error “Fix rigid: Bad Principal moments”. With the small number of random molecules (less than 10), this command is working fine with the framework. The problem occurs when the molecules exceed 10. The dump file after minimization suggests that the atoms are minimized appropriately. The framework is frozen with setforces to zero.
There are no overlapping atoms as well.
I tried to attach the file with the thread but couldn’t do so. Following is the datafile script:
units real
atom_style full
pair_style hybrid/overlay lj/cut/coul/long 12.0 lennard/mdf 11.0 12.0
kspace_style pppm 1.0e-5 #ewald
bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style none
read_data Framework.data
region box block 0 24 31.0 50.0 0 105
molecule CO2 CO2_EPM2_upd.mol
create_atoms 0 random 300 885631 box mol CO2 154798
set type 1 charge 0.999
set type 2 charge 1.668
set type 3 charge -0.889
set type 4 charge 0.6512
set type 5 charge -0.3256
group framework type 1 2 3
group co2 type 4 5
# Force-fields
pair_coeff 1 1 lj/cut/coul/long 2.6504000 2.6185000
pair_coeff 1 2 lj/cut/coul/long 0.2053280 3.0969000
pair_coeff 1 3 lj/cut/coul/long 6.2702000 1.1966000
pair_coeff 1 4 lj/cut/coul/long 0.0702167 3.2901500
pair_coeff 1 5 lj/cut/coul/long 0.1187568 3.4281500
pair_coeff 2 2 lj/cut/coul/long 0.4780000 2.3705000
pair_coeff 2 3 lennard/mdf 0.0000009 0.0000000
pair_coeff 2 4 lj/cut/coul/long 0.1634631 2.5637500
pair_coeff 2 5 lj/cut/coul/long 0.2764637 2.7017500
pair_coeff 3 3 lj/cut/coul/long 0.0002730 4.7441500
pair_coeff 3 4 lj/cut/coul/long 0.0881482 2.9239500
pair_coeff 3 5 lj/cut/coul/long 0.1490842 3.0619500
pair_coeff 4 4 lj/cut/coul/long 0.0559000 2.7570000
pair_coeff 4 5 lj/cut/coul/long 0.0945432 2.8950000
pair_coeff 5 5 lj/cut/coul/long 0.1599000 3.0330000
pair_modify tail yes mix arithmetic
# but meant to be rigid?
bond_coeff 1 11500 1.149
angle_coeff 1 11500 180
# Simulation Protocols
dump molecule_structure_init all custom 10 traj-nvt-init.lammpstrj id mol type x y z ix iy iz
velocity framework set 0.0 0.0 0.0
fix freeze framework setforce 0.0 0.0 0.0
minimize 1.0e-6 1.0e-7 1000 10000
velocity all create ${Tinit} 5871232 rot no dist gaussian
fix integrate_nvt co2 rigid/nvt/small molecule temp ${T} ${T} 50
fix rmMom co2 momentum 1 linear 1 1 1
undump molecule_structure_init
timestep ${dt}
reset_timestep 0
dump molecule_structure all custom 1000 traj-nvt.lammpstrj id mol type x y z ix iy iz
compute rmsd co2 msd com yes
fix rmsd co2 ave/time ${sampint} ${corrlen} ${nevery} c_rmsd[1] c_rmsd[2] c_rmsd[3] c_rmsd[4] file co2_${count}.msd
compute pp_co2 co2 stress/atom NULL
compute p_co2 co2 reduce sum c_pp_co2[1] c_pp_co2[2] c_pp_co2[3]
variable press_co2 equal -(c_p_co2[1]+c_p_co2[2]+c_p_co2[3])/(3*vol)
#fix press_co2 co2 ave/time ${sampint} ${corrlen} ${nevery} v_press_co2 file co2_${count}.press mode vector
compute myTemp co2 temp
thermo_style custom step pe density temp c_myTemp press v_press_co2
thermo ${ndelay}
neighbor 2.0 bin
neigh_modify exclude group framework framework
run ${t_nvt}
write_restart eq.co2
Following is the log error:
ERROR: Fix rigid: Bad principal moments (src/RIGID/fix_rigid_small.cpp:2322)
Last command: run ${t_nvt}
I would be happy if you help me out with this.
Please let me know if you need additional information.
