I am simulating rod suspensions! I assemble rods by sticking many beads to together via fix rigid command! at several times, I need to perform energy minimization, but since energy minimization is not compatible with fix rigid I can’t do that!
Would you please let me know if there are any effort to implement energy minimization in fix rigid command!? and do you have any suggestion of rme to do energy minimization in my simulation!?
Thank you
-Navid Kazem
I can’t do that!
as has been stated before. minimization for extended rigid objects is
a non-trivial thing.
you can always use simulated annealing e.g. via initializing a high
temperature and then annealing with fix viscous or through a properly
programmed temperature ramp on a compatible thermostat.
no there is not - if you want to tackle it, go for it.
