Hi all,
I am modelling DNA as a cylinder (a few atoms at the center) with phosphate on the surface of DNA forming double strands. The DNA is rigid(central atoms + phosphates (2 strands) and I want to let it to rotate around the central axis. I am trying to use “fix rigid” in a very simple system of just 2 DNA (two rigid bodies). 2 DNAs are initially parallel along z axis (separated along x axis). As I ran the code 2 DNA tilts (not parallel any more) although I have turned off x and y component of Torque and all Force components.
I want them to remain parallel to each other and only rotate along z axis. Is there anything that I have not considered?
BTW there is periodic boundary condition in the system and DNA is repeated along the z axis.
I really appreciate any help.
Shahzad
group rodions1 type 1
group rodions2 type 2
group hrod1 type 3
group hrod2 type 4
group ax type 1 2
group rods type 3 4
group r1 type 1 3
group r2 type 2 4
group r type 1 2 3 4
mass 1 20
mass 2 20
mass 3 20
mass 4 20
#set group rodions1 image NULL NULL 0
#set group rodions2 image NULL NULL 0
#set group hrod1 image NULL NULL 0
pair_style lj/cut/coul/long 10
pair_coeff 1 1 0.0 1.0 # Rodion1-Rodion1
pair_coeff 1 2 0.0 1 # Rodion1-Rodion2
pair_coeff 2 2 0.0 1.0 # Rodion2-Rodion2
pair_coeff 1 3 1.553 9 18 # Rodion1-hrod1
pair_coeff 2 3 0 0 # Rodion2-hrod1
pair_coeff 3 3 0.0 1 # hrod1-hrod1
pair_coeff 1 4 0.0 0 # Rodion1-hrod2
pair_coeff 2 4 1.553 9 18 # Rodion2-hrod2
pair_coeff 3 4 0.0 1.0 # hrod1-hrod2
pair_coeff 4 4 0.0 1.0 # hrod2-hrod2
kspace_style ewald 0.0001
dielectric 72
neighbor 2.0 bin
#fix 3 rodions1 setforce 0.0 0.0 0.0
#fix 4 rodions2 setforce 0.0 0.0 0.0
#fix 1 all rigid group 2 hrod1 hrod2 force * off off off torque * off off on
fix 1 r1 rigid single force 1 off off off torque 1 off off on
fix 2 r2 rigid single force 1 off off off torque 1 off off on
dump 1 hrod1 custom 1000 rod1 id type x y z
dump 2 hrod2 custom 1000 rod2 id type x y z
dump 3 ax custom 1000 ax id type x y z
