@akohlmey I used the tarfile from Download LAMMPS (Stable release 29 Aug 2024) and also tried the tarfile in Release Update 1 for Stable release 29 August 2024 · lammps/lammps · GitHub. Both give the error mentioned above.
The output from lmp -h | head -100 for the update 1 version is below.
Large-scale Atomic/Molecular Massively Parallel Simulator - 29 Aug 2024 - Update 1
Usage example: lmp -var t 300 -echo screen -in in.alloy
List of command line options supported by this LAMMPS executable:
-echo none/screen/log/both : echoing of input script (-e)
-help : print this help message (-h)
-in none/filename : read input from file or stdin (default) (-i)
-kokkos on/off … : turn KOKKOS mode on or off (-k)
-log none/filename : where to send log output (-l)
-mdi ‘’ : pass flags to the MolSSI Driver Interface
-mpicolor color : which exe in a multi-exe mpirun cmd (-m)
-cite : select citation reminder style (-c)
-nocite : disable citation reminder (-nc)
-nonbuf : disable screen/logfile buffering (-nb)
-package style … : invoke package command (-pk)
-partition size1 size2 … : assign partition sizes (-p)
-plog basename : basename for partition logs (-pl)
-pscreen basename : basename for partition screens (-ps)
-restart2data rfile dfile … : convert restart to data file (-r2data)
-restart2dump rfile dgroup dstyle dfile …
: convert restart to dump file (-r2dump)
-restart2info rfile : print info about restart rfile (-r2info)
-reorder topology-specs : processor reordering (-r)
-screen none/filename : where to send screen output (-sc)
-skiprun : skip loops in run and minimize (-sr)
-suffix gpu/intel/kk/opt/omp: style suffix to apply (-sf)
-var varname value : set index style variable (-v)
OS: Linux “Ubuntu 22.04.5 LTS” 6.8.0-51-generic x86_64
Compiler: GNU C++ 11.4.0 with OpenMP 4.5
C++ standard: C++11
MPI v1.0: LAMMPS MPI STUBS for LAMMPS version 29 Aug 2024
Accelerator configuration:
FFT information:
FFT precision = double
FFT engine = mpiFFT
FFT library = KISS
Active compile time flags:
-DLAMMPS_GZIP
-DLAMMPS_SMALLBIG
sizeof(smallint): 32-bit
sizeof(imageint): 32-bit
sizeof(tagint): 32-bit
sizeof(bigint): 64-bit
Available compression formats:
Extension: .gz Command: gzip
Extension: .bz2 Command: bzip2
Extension: .zst Command: zstd
Extension: .xz Command: xz
Extension: .lzma Command: xz
Installed packages:
MANYBODY
List of individual style options included in this LAMMPS executable
atomic body charge ellipsoid hybrid
line sphere tri
respa verlet
cg fire/old fire hftn quickmin
sd
adp airebo airebo/morse atm bop
born buck buck/coul/cut comb comb3
coul/cut coul/debye coul/dsf coul/wolf meam/c
reax reax/c mesont/tpm eam eam/alloy
eam/cd eam/cd/old eam/fs eam/he edip
edip/multi eim extep gw gw/zbl
hybrid hybrid/omp hybrid/molecular
hybrid/molecular/omp hybrid/overlay hybrid/overlay/omp
hybrid/scaled hybrid/scaled/omp lcbop lj/cut
lj/cut/coul/cut lj/expand local/density meam/spline meam/sw/spline
morse nb3b/harmonic nb3b/screened polymorphic rebo
rebomos soft sw sw/angle/table sw/mod
table tersoff tersoff/mod tersoff/mod/c tersoff/table
tersoff/zbl threebody/table vashishta vashishta/table yukawa
