Thank you so much for your thorough explanation, i used fix rigid for the atoms and i want to move them with constant velocity while atoms in my rigid body have interaction with the environment so i decided to use smd
how you move your atoms and which interactions are computed are two completely different things. there is no indication in the LAMMPS manual anywhere that this would be different.
