Hello Everyone,
I have recently started using LAMMPS. My system consists two single wall carbon nanotubes in aqueous dispersion.
I am carrying out Umbrella Sampling simulations (using fix spring) at varying separations (7-18 angstrom) along x-axis between the two tubes. I am using CHARMM force field. Simulation time is 10 ns.
I am using the following fix spring command:
fix 1 cnt1 spring couple cnt2 0.5 1.0 0.0 0.0 18
where cnt1 and cnt2 are the two groups of atoms and R0 is 18 angstrom and spring constant = 0.5
I start at a separation of 18 angstrom between the tubes and then attach the spring. I want the equilibrium separation along x-axis between the two tubes to be 18 angstrom after attaching the spring. Then eventually I unfix the spring and again fix it for a smaller separation (17, 16 , 15,…,7 angstrom)
At 18 angstrom separation, the average centre to centre distance between the tubes remains around 18 angstroms. However, at lower separations, the average distance between the tubes are around 14 angstroms (even if I’m specifying it to be 7 angstrom by fix spring command). But X component of the displacement vector remains around the value I’m specifying.
Lammps manual says, " The groups are coupled together by a spring that is at equilibrium when the two groups are displaced by a vector x,y,z with respect to each other and at a distance R0 from that displacement. Note that x,y,z is the equilibrium displacement of group-ID2 relative to the fix group. Thus (1,1,0) is a different spring than (-1,-1,0). "
My question:
Does that mean the separation between the two groups will be magnitude of the x,y,z vector + R0 ?
How should I use the fix spring command so that the equilibrium separation (along x-axis) will be R0?
Another relevant information is: I’m also trying to restrict the motion of the two tubes only along x-axis. But they moves along y and z too. May be that’s why I’m getting a value where y and z components of the displacement vector are also contributing. If so, is there a way two restrict the motion of the two tubes only along x-axis? I am planning to use velocity command to make velocity along y and z axis to be zero. Is this a correct way to do that?
I would really appreciate if any one can help me on this.
Thank you in advance, for your time and consideration in answering my query.
regards,
Nabaneeta
