I’m trying to squeeze my molecule in simulation box and see the effect of pressure by moving walls. I use wall/reflect and NVT for time integration. but I don’t see signeficant pressure change in the course of run. Niether I see any moving in boundary walls in VMD. is it because of NVT setting? is there another time integration to use with “fix wall/reflect”?
here is the input file that I use:
units lj
boundary f f f
atom_style angleread_data data_long.dat
read_dump dump.md 1020000 x y z
velocity all create 0.1 23656 dist gaussianbond_style harmonic
bond_coeff 1 1 1.2pair_style lj/cut 10
pair_coeff 1 1 0.2 1.0
pair_modify shift yes
pair_coeff 1 2 1.0 1.0 1.122
pair_coeff 2 2 1.0 1.0 1.122neigh_modify page 30000
neigh_modify one 3000angle_style harmonic
angle_coeff 1 10 180
angle_coeff 2 0.0 180fix 1 all nvt temp 0.1 0.1 0.1
lattice fcc 0.003
variable ramplo equal ramp(-50,-0.0002)
variable ramphi equal ramp(50,0.0002)
fix walls all wall/reflect xlo v_ramplo xhi v_ramphi ylo v_ramplo yhi v_ramphi zlo v_ramplo zhi v_ramphithermo 2000
dump 1 all custom 3000 ext_chain_long_bnd_no_interaction_wall.md id type xu yu zu
timestep 0.000005
run 100000
Hamed.
