Fixing More Than 32 Particles as Harmonic Springs in LAMMPS
Dear LAMMPS-Users,
Good morning. I would like to fix a number of particles in my system as harmonic springs via the fix spring command with the tether keyword, but I need more than 32 groups. I am limited by cell size and must have a minimum of 64 cells. There is 1 harmonic particle per cell, which needs to be declared explicitly to fix it to its current position. Therefore, I would need:
fix ID groupID spring tether k x1 y1 z1 R0
fix ID groupID spring tether k xN yN zN R0
in order to fix each particle in each cell to its current position. Is there an efficient way to get around this? I have read the manual, but perhaps more experienced users can suggest a trick of the trade.
Thank you, and have a great day.
Christin
Dear LAMMPS-Users,
move the atoms where you need then and then use
fix spring/self
this way you need only one group.
